Why Half the Tread Depth?
Old Jul 4, 2010 | 08:06 PM
DukeofEarl's Avatar
DukeofEarl
Question Why Half the Tread Depth?
Did a search with no answer. Anyone know why the front tire has half the tread depth of the rear when brand new? 5/32s versus 10/32s.
Old Jul 4, 2010 | 08:09 PM
flhxkiller's Avatar
flhxkiller
maybe so they wear out at the same time?
Old Jul 4, 2010 | 08:26 PM
krwould's Avatar
krwould
Makes some sense to me... rear tire is doing all the work and is the drive tire,, front one just goes along for the ride,,, I found I change front ones once to every three rear tires on my bikes..
Old Jul 4, 2010 | 08:59 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Maybe they are thinking that a front tire with 11/32" tread would be courting dry rot problems before the tread is gone??
Old Jul 5, 2010 | 04:44 AM
kingkingking's Avatar
kingkingking
Its to stop block squirm under brakes which causes the feathering issue that the D407s are famous for.
http://w6rec.com/duane/bmw/cupping/index.htm
Old Jul 5, 2010 | 05:48 AM
emwolb's Avatar
emwolb
it's probably because the rear tires outlast the fronts by at least 2 and in some cases, three rears per front considering the wear.
Old Jul 5, 2010 | 06:00 AM
mtairy biker's Avatar
mtairy biker
it don't matter to me when I change tires I change both anyway. I have never belived in the 2 back to one front B.S. there is something about 2 new & stickey tires on a bike
Old Jul 5, 2010 | 03:10 PM
tphillips's Avatar
tphillips
Originally Posted by mtairy biker
it don't matter to me when I change tires I change both anyway. I have never belived in the 2 back to one front B.S. there is something about 2 new & stickey tiers on a bike
Throwing your $$$ away on the new front tire that often. Yes, you can get 1 tire's life in front for each 2-3 tires you wear through on the rear. Just wanting to replace it each time is a matter of preference. But it doesn't become less "sticky" or wear out that fast.
Old Jul 5, 2010 | 03:55 PM
BBStacker's Avatar
BBStacker
Found this on the web in less than 2 minutes only because I really never gave it a thought. Just change em when I need to.
"Rear tires are harder rubber, designed to carry more weight, designed to resist the shear of torque from being a drive tire, and the tread is different since it is not designed to be changing alignment with the body and track of the motorcycle as a front tire does."
Makes sense when you think about it. Hope this answers your question.
Old Jul 5, 2010 | 05:12 PM
qtrracer's Avatar
qtrracer
mtairy biker is right, as rubber ages and heat cycles it becomes harder or less sticky. Not throwing money away at all changing both at the same time.
