need advise
Old Jul 7, 2010 | 09:10 AM
ncdan's Avatar
ncdan
Default need advise
My bike is an 03 electra glide classic. A few months ago I installed a set of ss 510 cams, filter upgrade an a set of sampson slipons, and had a dyno tume preformed. I ended uo with 76 hp and 81 tourque, not much bennifet for 1500 bucks. After the, so called, upgrades were done my wife and I decided the noise leavel was a little to much for long distance touring. My question is can I put my stock muffflers back on without looseing my few hp gains. My stock mufflers have been opened up a little befor I did the cams. Experienced advise appreicated.
Old Jul 7, 2010 | 12:46 PM
Bodean46's Avatar
Bodean46
I have basically the same build but had mine tuned at Doc's in St. Louis and you can see my torque is way better than yours. Might need to have it re-tuned. My Wild Pigs aren't overly loud as the wife says she hardly notices them.
Old Jul 7, 2010 | 04:04 PM
bagman1's Avatar
bagman1
Same build, check out my numbers. Id say get a good tune, by increasing back pressure as in stock pipes you will give up numbers, again see my numbers.
Old Jul 7, 2010 | 07:46 PM
BLKBAGGER's Avatar
BLKBAGGER
Im not a fan of Sampson pipes slip-on or otherwise. And yes you will get some torque back with stock slip-ons. A 2 into 1 would give you the best results.
oct1949
May 18, 2026 09:56 AM
chgofirefighter
Apr 28, 2014 01:43 PM
mainboom150
Jul 16, 2013 07:01 PM
cobaltking
Exhaust System Topics
Nov 4, 2007 03:38 PM
ScooterJammer
May 14, 2007 05:48 PM
