shimming rockers?
Old Jul 7, 2010 | 06:01 PM
cuda67bnl's Avatar
cuda67bnl
Default shimming rockers?
I want to shim my rockers in an effort to reduce some of the extra noise. Any suggestions on just how tight of a tolerance I should shoot for?
Old Jul 7, 2010 | 07:03 PM
dawg's Avatar
dawg
According to manual, if more than .025 end play then you should replace. Having said that, I know of people that shim and leave about .004 space with the shim and are happy. Realigning the rockers (i.e. pushing to the right side while tightening to align the pushrods in center) will also decrease noise as well. Depending on the mileage, you may want to check the bushings and all as they can be out of round. If high mileage, you might benefit from replacing the rockers and supports, etc.
Old Jul 7, 2010 | 08:18 PM
cuda67bnl's Avatar
cuda67bnl
Thanks, Dawg. My front rockers have .011 clearance on both shafts, and my rears have .014. I had heard about pushing them when retightening, but I couldn't recall which way to push them. Are you saying I need to push them towards the intake side, or towards the front when you say 'right'?
Old Jul 7, 2010 | 08:25 PM
dawg's Avatar
dawg
Towards the intake
Old Jul 7, 2010 | 08:35 PM
cuda67bnl's Avatar
cuda67bnl
Awesome. Thanks again.
Old Jul 7, 2010 | 08:49 PM
1931jamesw's Avatar
1931jamesw
Are you just going to try that cuda? Post again if you get it quietened down. I'd like to know what the fix is.
Old Jul 7, 2010 | 09:11 PM
WI Bob's Avatar
WI Bob
Where does one buy the shims?
Old Jul 7, 2010 | 09:12 PM
dawg's Avatar
dawg
Mcmaster Carr or the like
Old Jul 7, 2010 | 09:16 PM
dawg's Avatar
dawg
http://www.mcmaster.com/param/asp/PS...MainWidth=1068
Old Jul 7, 2010 | 09:20 PM
dawg's Avatar
dawg
BTW, place the shims on the non thrust side of the rocker arm. Exhaust shims go on left side and intakes go on right side.
