Car tire....mmmm...Dark side section
Come on guys... A f'ing car tire on your bike! What next - some fenders, a hood, trunk, & power windows...????....
I spent four months studying before becoming totally convinced and going over. I won't be going back. I'll be referring them to here:
https://www.hdforums.com/forum/softa...ml#post6996350
Where I'm chronicling the experience and performance, good or bad. Not much bad, I have to say.
Although like a member said in a different CT/MT thread, (cats will soon be screwing dogs), all brought on by are alternative lifestyle brethren!
http://www.motorcyclecruiser.com/roa..._v8/index.html
Excerpt:
With 130/90-16 Continental motorcycle tire on the front wheel and that big, square-profile Firestone P225/70R15 radial car tire on the back, we anticipated all sorts of adventures in corners. We were therefore extremely and pleasantly surprised to discover that the Boss Hoss actually tracked pretty precisely and smoothly around as many corners as we could find in south Florida. It steered with no more force than needed for other "big" bikes. We suspect that the makers of the tires shudder to think of their products being used in that context and combination, but at least on dry pavement, we couldn't find much to quibble about. You could tell that the rear tire's profile wasn't rounded like a motorcycle tire's, but you can confidently lean it over far enough to drag things, which requires more lean angle than many cruisers.
The considerable contact patch of the tires also helps the big bike get stopped in a reasonable distance. Although you need to apply relatively strong pressures, the bike will stop pretty hard. The dual-disc front brake requires strong pressure, and you also need to use the rear brake, which sports a very large disc, more than on most other bikes because of the long wheelbase and considerable traction available at the rear.
Twisting the throttle while in neutral and the bike will just about twist out from under the rider due to the torque of the engine.
