Headquaters Cams
Old Jul 13, 2010 | 08:10 PM
Mongo40's Avatar
Mongo40
Like I said there is no writing on it so I'm assuming its a washer but it was in its on plastic bag in with the cams. I've used this indy for years, he's been in buisness for 20 something years, but he definitly threw me when he called to ask for instructions, he stated that because they were not harley cams and they were made different, had a different shaft diameter, that he wasn't sure what the washer was for as there wasn't one on the stock cams.
Old Jul 13, 2010 | 08:22 PM
cuda67bnl's Avatar
cuda67bnl
Got to be either the thrust washer for the front cam, or a spacer washer for the rear.
Old Jul 13, 2010 | 09:33 PM
Mongo40's Avatar
Mongo40
I hate to start putting it back together till I figure out where that washer is supposed to go.
Old Jul 13, 2010 | 10:13 PM
Teardrop's Avatar
Teardrop
I would email HQ and ask them where it goes..........
Old Jul 13, 2010 | 10:20 PM
1931jamesw's Avatar
1931jamesw
It's most likely a spacer. As mentioned above they make several different thicknesses of them and they are used to align the cam sprockets. It talks about this in your service manual.
Old Jul 13, 2010 | 10:33 PM
Harleypingman's Avatar
Harleypingman
You can phone or email Kevin at Pro Twin Performance, HQ's exclusive US retail vendor:
http://protwin.com/index.aspx
And you can join HQ's forum for the information you want:
http://www.head-quarters.com/html/q___a_group.html
Which HQ cams do you have and what are they going in?
Carl
Old Jul 13, 2010 | 10:34 PM
stafford's Avatar
stafford
If it's a pretty thick washer, say around .100 it goes on the rear cam put your 34 tooth sprocket on , then the washer then put it into the camplate and put the outer gear. check to see that you hyave between .008/.012 endplay in each of the cams after they're installed.
Hope that helps
Old Jul 13, 2010 | 11:15 PM
Mongo40's Avatar
Mongo40
Stafford it is pretty thick, about like a normal washer would be, but I'm not following your instructions, could be cause I'm just getting tired. Are you saying the washer should go on the cam then install the cam into the cam plate or does it go on the outside of the cam plate once the cam has been pressed in??
Old Jul 14, 2010 | 01:58 AM
stafford's Avatar
stafford
Talking
Yes it goes on the cam and then the cam into the plate
Old Jul 14, 2010 | 11:22 AM
stafford's Avatar
stafford
maybe this'll help.
http://www.andrewsproducts.com/PDF_f...n_chain-01.pdf
Mars47
May 24, 2015 11:19 AM
Iron lHorse
Oct 25, 2013 10:37 PM
fj4069
Exhaust System Topics
Mar 17, 2008 07:10 AM
damadman
May 15, 2007 09:53 AM
HDF Tech
Engine Mechanical Topics
Oct 22, 2005 11:46 AM
