Speaker Opinions.
For once at least HD has surprised me as these little buggers really crank.
Thinking about adding the bass port kit now for just a little more bottom end.
I had some 4 ohm alpine components powered by a 2 ohm ARC amp and didn' think they sounded all that great. I changed those out to the J&M 7.25's which are 2 ohm and it sounds a whole lot different.
As far as water, I believe unless you have that outer fairing totally sealed up to the inner fairing, water will find it's way in there. If your worried about that, I suggest you find some marine speakers instead. Since you got those Pioneers for free, I would just run those until something happens.
I have some type of insulation in my fairing and really can't tell the difference from when I didn't. You will find some people here that swear by it. If you end up purchasing the J&M's, they come with some insulation and you might as well try it out since they come with it. I didn't install mine because I already had something in there before I got the J&M's.
Thanks for the info. That will help alot. Ill have to check the speakers I have. Is the ohm rating for the factory deck available somewhere. Also who do you recc in the aftermarket to sort this stuff out. I need 6.5 adapters and other items possibly. Thanks KC
two 2010 Road Glides with stock Harley HK radios, no amps ,,,,,, one with the new Harley BOOM speakers with single grill mounted tweeter ,,,, other with the J&M 7.25" speaker upgrade, with grill mounted tweeter and midrange ,,,,,,
same CD ,,,,, same volume settings on radios ,,,,,
the bike with the J&M's had significantly more bass and just a lot more sound in general,,,,,,
the opinion was unanimous among 5 different guys all standing around the bikes ,,,,,
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Not a problem, that is why there are choices in the world and thank the lord we have them ,,,,
Please remember that we also offer our performance speaker upgrade in the 5.25" size for $129.99 list price ,, see http://www.jmcorp.com/ProductDetail....-09GTM-B&PF=43 ,,,,
these smaller 5.25" J&M's will outperform the Harley stock and BOOM audio speakers also ,,,,
