Checking Air Pressure in Shocks
Old Jul 15, 2010 | 08:26 AM
t059736's Avatar
t059736
Default Checking Air Pressure in Shocks
Good morning, guys.
Just read the "front" page of the forum; regarding checking the shock air pressure, "How many of you put your scoots up on the jack to measure the shock pressure?"
I've not read or heard about this before?
Ride In Peace
Old Jul 15, 2010 | 08:36 AM
valvestem's Avatar
valvestem
Originally Posted by t059736
Good morning, guys.
Ride In Peace
I never have in 10 years of having air-adjustable shocks.
Old Jul 15, 2010 | 08:40 AM
Zimbob's Avatar
Zimbob
I had some smarta$$ thing to say but, I check mine with it on the kickstand. Never heard of any other way.
Old Jul 15, 2010 | 08:49 AM
Texas Fat Boy's Avatar
Texas Fat Boy
I've never heard of this. Sounds stupid to me.
Old Jul 15, 2010 | 08:51 AM
Toypuller's Avatar
Toypuller
That would make checking them on a road trip a real pain in the ***.
Old Jul 15, 2010 | 08:56 AM
t059736's Avatar
t059736
Did any of you read the "lead in" page?
It's posted by HD - so maybe - STUPID is as........
Ride In Peace
Old Jul 15, 2010 | 09:19 AM
Theakerr's Avatar
Theakerr
For an absolute pressure reading the statement is correct. However, what matters is what pressure works for you, just use any published number as a guide. Provided you measure the pressure in a constant manner and use that as your reference you will be OK. Thus, if you set the pressure at 18 psi in the side stand and for you at your weight and loading conditions that works, then that what you use as your target. I just happen to set the pressure when the bike is on the centre stand and for my weight and normal loading 20 psi is my setting target.
Old Jul 16, 2010 | 03:29 AM
White Knight 04's Avatar
White Knight 04
Where 's my slide rule and calipers ?? Unless they have improved them since 04 I would take them off and throw them in the nearest garbage can... Then put on a good set of progressives !!! That is exactly what I did... Harley shocks are junk IMO......
Old Jul 16, 2010 | 03:43 AM
shortride's Avatar
shortride
If I remember correctly, the owners manual on my GL1800 Goldwing states to check and adjust the rear shock pressure while on the center-stand. That's because it didn't require a pre-load. I don't think that the case with a Harley.
Old Jul 16, 2010 | 05:54 AM
dansflhti's Avatar
dansflhti
According to the 09 Touring service manual,"always adjust pressure with the motorcycle on the jiffy stand."
