SE clutch spring question
Old Jul 19, 2010 | 02:00 PM
1931jamesw's Avatar
1931jamesw
Iclick makes a good point. Do not use a synthetic in the primary.
Old Jul 19, 2010 | 02:27 PM
WILLETTS's Avatar
WILLETTS
just an 07 stage one street glide. I will double, triple check the adjust and cable tension. Using ATF already. Does not sound as if I need the heavy spring. I guess if unable to rid the problem I may need to remove and inspect the plates, maybe the previous owner did not service or was hard on the clutch, who knows
Old Sep 2, 2010 | 07:14 AM
WILLETTS's Avatar
WILLETTS
Well finally got around to installing the SE clutch spring, slippage gone. I guess the original diaphragm spring was worn out. CLutch feels nice and smooth now. It is harder to pull but after about 3 minutes I didn't even notice it. None of the local dealers had the older version spring. Love it when a plan comes together.
Old Nov 9, 2014 | 03:49 PM
Bagger_Vance's Avatar
Bagger_Vance
deleted
23Seven
Apr 9, 2019 01:11 AM
otto76689
May 10, 2017 04:02 PM
128auto
Jul 22, 2015 08:18 PM
jcbpa
Nov 18, 2008 10:50 PM
Ultra61
Mar 16, 2008 11:51 AM
