Tire Question
Old Jul 20, 2010 | 07:11 PM
Mike in Oregon's Avatar
Mike in Oregon
Question Tire Question
Going to put new tires on ASAP. What to know what is the widest back tire that will fit, and what to do for the front???
Old Jul 20, 2010 | 08:04 PM
Mike in Oregon
While taking both wheels off I noticed I have a ton of space on the right side between tire and swing arm. However on the left I have no room due to the plastic belt guard. If I removed it, it would allow for a much wider tire!
Old Jul 20, 2010 | 08:33 PM
BoomerBob's Avatar
BoomerBob
I think the 05 RK is a 150 mm wide tire - stock. You can go to 160 mm. As a general rule you can go 10 mm over stock. You might be able to go wider if you take some measurements and are willing to go without the top belt guard. How does the clearance with the lower belt guard look?
A member, Quadancer, recently put a 175 mm wide car tire on his 05 Heritage and it runs a 150 stock.
Old Jul 20, 2010 | 09:00 PM
Mike in Oregon
That was the lower guard. I have no upper guard.
Old Jul 21, 2010 | 04:52 AM
grbrown's Avatar
grbrown
I have an 07 swingarm in my bike and can get a 150 in with ease, although my older rear fender is very snug. A 160 might fit a later bike with a modified lower belt guard. Be aware that fitted widths of tyres vary considerably. My 150/80 Avon is actually 153mm wide, although Avon say on their website it will be just 150mm wide. When running close to the limit on clearances, such things can be the difference between success and drat!
Old Jul 21, 2010 | 10:27 AM
Mike in Oregon
I'm vary limited with a 3" wide wheel too! I'm thinking a 150-160 will be the limit.
Old Jul 21, 2010 | 10:37 AM
dirtracin23's Avatar
dirtracin23
The stock rear is a 130. You can go up to a 150 with no problem and I have read on this forum of some going up to a 160.
Old Jul 21, 2010 | 11:00 AM
grbrown's Avatar
grbrown
Thumbs up
A 150/80 it the largest on a 3" rim, although I suspect someone has fitted a 160! My 150/80 fits with just enough clearance and works well for me.
slowboy
Wheels/Tires
Mar 21, 2019 10:50 AM
R Hill
The Dark Side
Feb 16, 2014 04:39 AM
kage
Wheels/Tires
May 1, 2012 10:56 AM
cycletrash98
Apr 30, 2009 06:47 PM
STREETGLIDEROD
May 27, 2008 09:06 PM
