running lean vibration
Old Jul 24, 2010 | 05:39 AM
ricaroo's Avatar
ricaroo
Default running lean vibration
I had a stage 1 done and the bike vibrates in the floor boards and highway pegs at certian rpms Would a set of xieds richen it up enough to get rid of the vibration?
To make it short will a lean running motor cause vibration?
2008 ultra V&H true dual headers high flow A/C modified oem muflers.
thx
rick
Old Jul 24, 2010 | 09:07 AM
TMair's Avatar
TMair
Mine has a stage one on it, I just had the cam tensioners replaced and mine is acting exactly like what you describe, I would like to know the answer to this vibration too.
Terry
Old Jul 24, 2010 | 09:21 AM
head's Avatar
head
my 2006 flhri had the stage one done on it before i bought it. it shakes real bad at idle.more than most ive seen. other than that,its smooth as silk. i have noticed that when i'm out and about riding and after the bike gets much hotter, the timing retards a bit and the idle is very smooth. have been wondering what i can do about the idle shake. it has the shifter moving up and down pretty bad at idle.
head
Old Jul 24, 2010 | 09:48 AM
VETERAN75's Avatar
VETERAN75
If you had a full exhaust added make sure it isn't hitting anything anywhere. It should only touch at the mounting points.
Old Jul 24, 2010 | 01:45 PM
TMair's Avatar
TMair
head
not sure I totally understand, so when it gets warmed up it idles better then when cold, or is this a typo?
Terry
Old Jul 24, 2010 | 07:12 PM
head's Avatar
head
thats exactly right.when you first crank it and for as long as it sits until youre ready to roll, its shakin and bakin. but if i happen to ride into town in the summer like today and stop at a traffic light after a few miles, the idle is smooth as can be. i say idel but i should say the motion of the rubber mounted engine. the idle itself is fine. the engine is just all over the place.
i read that as the fuel injected twin cam motor heats up, the computer retards the timing as needed. i assume this is what is smoothing things out. its not a big deal. just not something that i am used to.
head
Tucker99
Mar 19, 2017 01:41 PM
ricaroo
16
May 13, 2011 09:34 AM
tincup64
Jun 20, 2010 09:55 PM
ricaroo
Jun 15, 2010 02:23 PM
pingman68
Jun 12, 2008 02:03 PM
