How much air pressure
Old Jul 26, 2010 | 12:32 PM
HDBRATT's Avatar
HDBRATT
OK I am running 42...I am doing something wrong huh? I will try and let it out to 25 then will probably drop it to 20. I ride solo. How do you determine what is the right number...trail and error?
Old Jul 26, 2010 | 01:04 PM
barjbar's Avatar
barjbar
I'm at about 15 and weigh 155 and usually ride solo. Maybel I'll increase mine to about 25.
Old Jul 26, 2010 | 01:31 PM
frenchbiker's Avatar
frenchbiker
35psi
I haven't tested with more or less air than that in the shocks. The suspension feels fine at 35psi. We ride duo all the time and our combined weight is 300lbs.
Old Jul 26, 2010 | 01:41 PM
wbogley's Avatar
wbogley
I run 35 psi. The service manual gives the ranges and I think it is 30-35 for two up and then you can go down for 1 up if needed.
Old Jul 26, 2010 | 02:55 PM
bellgnte's Avatar
bellgnte
It really is trial and error. My wife usually can tell because too soft will bounce her off the seat some. Everyone please remember though.....these bikes have some differences. Lot's of different years posting so I though I would mention it. I know the 09's have a max of 50lbs and the manual claims 40 for two-up riding. It works for us but we aren't very heavy. I think the pre-09 bikes had a much lower max rating. More like what WBOGLEY quoted.
Old Jul 26, 2010 | 03:15 PM
fyrfytr's Avatar
fyrfytr
6th Gear
Thanks for the info. I have been running about 18 lbs so i am going to try higher pressure and try to smooth out the ride.
Old Jul 26, 2010 | 04:20 PM
Texas Fat Boy's Avatar
Texas Fat Boy
I have changed my rear shocks to Ultra shocks so we now have the same ones.
I weight 220, I always ride solo and use 25 lbs. and use the hand pump.
It glides over Rail Road tracks now.
Old Jul 26, 2010 | 04:25 PM
SG 1's Avatar
SG 1
Never had any bottoming out problems but 30 is better than 15 for me. Just rides smoother. Same 2 up or single.
Old Jul 26, 2010 | 04:29 PM
isac's Avatar
isac
I have 50psi in my shocks all the time..1up 2up doesn't matter..works great for me
Old Jul 26, 2010 | 06:01 PM
Wassup8687's Avatar
Wassup8687
You are correct the pre 09 bikes max is much lower. Best to read the manual for your year so you don't blow them out.
