I am in agreement with the possibility of an aftermarket filter not having the by pass valve. Seems like the only logical explanation to me, assuming that it was amsoil that was in fact put in the first place...never know, who ever changed that oil might have just been mad at the world that day..just sayin
My noise issue was the compensator which I initially thought was engine noise (oil starvation) on start up. Oil needed changing anyway, so no lose. I'll continue to use Amsoil or Mobil 1 in the engine until facts are presented that shows they are harmful to the motor.
Sorry for not getting back sooner, I had to go out after my post and never got back. Never thought I would get this many responses. I will try and answer them all.
First off I have been doing my own oil changes on Harleys for over 45 years. Before the trip I put in Amsoil 20-50 with a new K&N oil filter. The oil had maybe 50 miles on it before I left. I have been running the K&N oil filter for over 10 years and using Amsoil for about 2 years with no problems. I get average about 42 mpg on the highway and do not believe the I am washing the cyl's with excessive gas as I have never smelled gas in any oil changes or seen the oil as thin. Also the trip out to Sturgis does not involve any steep grades where you coast down long grades. The mechanic at Black Hills Harley cut apart my K&N filter and found no metal particles in the can ( good thing). My motor had over 4K on my new build before this trip and had been through 2 oil changes with no issues.
After the teardown and installing HD syn oil I rode another 5k over the hot desert twice and the bike ran fine. No black oil when I changed it again back home and no engine noises, so I don't believe I have an engine problem. I am not trying to sway anyone either way about what oil they use, only relate what happened to me. I like many others have used many other brands of oil but, this is the first time this has happened to me with ANY oil. I am as perplexed about this as the many that have posted but, feel I can no longer trust this brand of oil.
Not trying to contradict your experiance but I'm from SD and have driven across the state may times and I can think of several long downhill grades off the top of my head. Like at the Missouri river crossing, a few miles west of Murdo and the Cheyenne river valley to name a few. I have paid close attention to these pulling a 32 foot travel trailer across state.
I went to auto zone here in boston the other day to get new oil for my bike. Im guesing my bike has the HD oil in it as I have never done an oil change yet. This will be be my first oil change on my bike and I bought Mobil 1 V twin 20w-50 oil for it. I took a while to find as it was hidden in the store and not near the Mobil 1 20w-50 "CAR" oil. So is there a difference from my v twin 20w-50 oil than your mobil 1 NON v twin 20-50 oil. I was told that all the other oils are meant for cars not motorcycles.
any input here???
I too bought the Mobil 1 V-twin oil at Auto Zone a few days ago. I went to Mobil 1's Web site and found lots of information. In particular I was curious about the manufacture date of the oil I bought because it had a different label than my last batch of Mobil 1 V-Twin. The date code was not entirely legible but they emailed me back to say the stuff I bought was made in 2009. They also say their oil has a shelf life of 5 years.
About your question in particular they say:
So how is Mobil 1 for passenger cars different from Mobil 1 for motorcycles?First, let's be clear about Mobil 1's overall benefits compared to those of conventional motor oils, whether for passenger cars or motorcycles:
Superior long-term engine protection.
Superior high-temperature stability.
Excellent low-temperature starting.
Outstanding engine performance.
Low volatility/low oil consumption
It's a little hard to generalize about the difference between Mobil 1 passenger-car motor oils and Mobil 1 motorcycle oils. That's because not all viscosities of Mobil 1 passenger-car oils have the same levels of zinc and phosphorus, and there are even greater differences among the three Mobil 1 motorcycle oils. In general, Mobil 1 motorcycle oils have:
Additive packages balanced differently for motorcycle engine and transmission operation. For passenger vehicles, fuel economy and emission system protection are higher priorities. These require low phosphorus systems and the use of friction modifiers. Motorcycle oils do not require friction modifiers for fuel economy and for better clutch friction less/no friction modifier is optimum. Motorcycle oils allow the use of higher levels of antiwear additives such as ZDDP (phosphorous).
I put amsoil in all 3 holes at my last oil change. After about 900 miles while i was checking the oil, it seemed real dark and rather thin. I ended up draining the oil with just over 1000 miles on it and it came out black and almost like water. I recently drained the primary to change out the clutch spring and it looked the same dark and very thin. Not sure what went wrong but Im not using Amsoil again
The Mobil tech and I talked about the non-mc oil for cars and since we don't have a clutch sharing the engine oil, he said it was fine to use, so It's been Mobil1 for me lately.
No problems at all.
I think Amsoil full synthetic or any full synthetic for that matter can not be blamed for this failure.
The failure was mechanical only.
Of any oil on the market Amsoil and Mobil 1 could never be blamed for an engine failure due to viscosity break down.
