Need some help how do I remove a compression release???
Old Jul 30, 2010 | 05:15 PM
HAG11Limited's Avatar
HAG11Limited
Default Need some help how do I remove a compression release???
Hello all I need some help I have a compression release that is sticking I want to remove it to clean it with some carb cleaner but I can't figure out how to remove the darn thing. It looks like a 1/2 deep well is the socket but I can't get it over the not sure if i am calling it by the proper name but the round part of the release that moves when you close them?? Any help would be greatful.
Old Jul 30, 2010 | 05:28 PM
BurgundyUltra06's Avatar
BurgundyUltra06
I don't remove mine to clean them, so I can't directly answer your question -- I didn't want to break the pressure seal. I just spray some WD-40 around the black push button (use little tube) and manually cycle them a few times. Wipe up the excess and you should be good to go. This procedure has been working for me for about 20K miles, and I do it every 6-7K miles (when they first start to show sticking conditions in my case).
Old Jul 30, 2010 | 05:59 PM
HAG11Limited
Worked like charm thanks I knew I could count on this forum
Old Jul 31, 2010 | 12:19 AM
emwolb's Avatar
emwolb
i use the same procedure with my manual compression releases. i found that if i use only the front compression release, it's the cylinder that is read for timing, and start it when i turn on the key rather than allowing the electrical system to determine that all light bulbs are functioning it starts easier too. i use either wd-40 but prefer using the power blaster, also known as pb with the yellow top. it's a penetrating oil and works great.
Old Jul 31, 2010 | 01:19 PM
BurgundyUltra06
Hag -- Glad to help you sir, that's what this forum is all about. I've received my assistance/rewards from this site as well. Safe and happy travels.
Old Jul 31, 2010 | 01:21 PM
chasswartz's Avatar
chasswartz
A 1/2 in, deep well, 12 pt socket works on mine.
TroutBum
Jan 4, 2019 09:57 AM
txdrifter8705
General Topics/Tech Tips
Jul 21, 2017 07:16 AM
RHillbilly
Nov 8, 2011 12:29 AM
jacknthebox
Oct 25, 2010 11:26 AM
bisonlee
Exhaust System Topics
May 3, 2008 09:19 PM
