need help
Old Nov 6, 2011 | 08:16 PM
RHillbilly's Avatar
RHillbilly
Default need help
anybody have a simple way to install piston pin clips,spent about 3 hrs on the first one finally got it kinda gave up on 2nd one after about an hr kinda scratches the piston around the clip doing it with a screw driver never had a problem before
Old Nov 6, 2011 | 08:24 PM
hatchetman's Avatar
hatchetman
Screw driver is too big. Get a small pointed punch or make one with a crappy old screw driver. Grind the end into a point. Put the clip in at the bottom & using the point in the top hole of the clip Pull down & push in.
They can be a real ***** but it works!
step #2 Go get you some snap ring pliers!!
Hatch.
Bill03E's Avatar
Bill03E
I use a pick, and put the bottom in , then roll it in with your thumb as you put pressure on it downward with the pick at the top.
Old Nov 6, 2011 | 08:25 PM
dawg's Avatar
dawg
3/4" copper coupling, insert the clip in the end, line the coupling up with the hole and use a 5/8" socket and drive it through the coupling thereby seating the clip.
Old Nov 7, 2011 | 04:56 AM
RHillbilly's Avatar
RHillbilly
Thanks dawg will try that
Old Nov 7, 2011 | 06:05 AM
RHillbilly's Avatar
RHillbilly
Old Nov 7, 2011 | 06:23 PM
classic53's Avatar
classic53
Now I gotta remember that! Very ingenious there dawg in finding/figuring that out!
Old Nov 7, 2011 | 06:32 PM
Uncle Larry's Avatar
Uncle Larry
The Dawg is showing his age ... that's an old trick ... and a good one! Be sure they are fully seated ( double check ) after you've gently knocked them in.
Old Nov 7, 2011 | 07:20 PM
RHillbilly's Avatar
RHillbilly
I tried the copper tubing but these clips are so stiff couldnt get them in the copper tubig.I was trying to put clips in like book said with open end up,called fuel moto and Keith said doesnt matter which way you put them in they went right in like that
Old Nov 8, 2011 | 12:29 AM
sgdiesel's Avatar
sgdiesel
Circlip pliers
KDUBYA
Engine Mechanical Topics
Apr 20, 2014 10:21 AM
SG2011PAYNE
May 12, 2013 07:54 PM
bubba 40
Shovelhead
Jan 9, 2010 12:56 PM
bisonlee
Exhaust System Topics
May 3, 2008 09:19 PM
NERider
General Topics/Tech Tips
Jul 21, 2007 06:39 AM
