Idle problem
Old Aug 1, 2010 | 10:18 AM
onaride63's Avatar
onaride63
Default Idle problem
Since I rebuilt my motor last winter. I have noticed that when I start up my bike it starts fine. While it's warming up and on high idle its fine but during the transition from high idle to normal idle it will sorta skip a beat and act like it's going to die and then catches it's self and continues to run ok. Then last night going to the store it died at a stop light. Over the past three yrs it has died while riding a few times but never throws a code. All grounds are ok and all electrical connections seem to be fine. any ideas ?
Old Aug 1, 2010 | 10:21 AM
soft 02's Avatar
soft 02
mine did that and it was the tps sensor and it did not through a code. 28 dollar sensor and all is well.
Old Aug 1, 2010 | 10:28 AM
onaride63's Avatar
onaride63
where is the tps located ? and is there a way to check it ?
Old Aug 1, 2010 | 10:34 AM
soft 02's Avatar
soft 02
Its on the throttle body oposit of where the throtle cable is connected. behind the ac on the left side of throttle body.
Old Aug 1, 2010 | 10:57 AM
onaride63's Avatar
onaride63
found it. duh, you would think I would look in my manual....not enough coffee yet.........
Old Aug 1, 2010 | 11:03 AM
soft 02's Avatar
soft 02
I wanted to test mine to be sure but I did not have the "elec diagnistic manual" that the service manual refers to but for 28 bucks I took a chance and got it on the first sensor I threw at it!
Old Aug 1, 2010 | 12:58 PM
Lonewolf176's Avatar
Lonewolf176
Just connect your SERT up and using data mode you should be able to check your tps. Key on, run switch on, engine not running you will be able to check voltage and % by just twisting the throttle.
Old Aug 1, 2010 | 01:00 PM
soft 02's Avatar
soft 02
holy crap I wish I knew that. Thanks
Old Aug 1, 2010 | 04:21 PM
onaride63's Avatar
onaride63
Thanks. 1 problem my pc has a 15 pin port not a 9. time to buy an adapter
Old Aug 3, 2010 | 03:14 PM
onaride63's Avatar
onaride63
I replaced the tps and so far it seems fine. I started it up twice and let it idle and no hickups. bike still seems to run good but it did before besides the idle thing. I guess time will tell. Thanks to those who through there 2 cents in to try and help me !
scotsport
Sep 21, 2013 03:43 PM
bkessler28
May 18, 2013 12:25 PM
AFblacksheep
Nov 9, 2012 12:45 PM
Onyx
Exhaust System Topics
Mar 23, 2012 09:56 PM
carlgrover
EVO
Feb 6, 2011 07:37 AM
