No more vroom vroom
Old Aug 1, 2010 | 03:51 PM
sgfdotcom's Avatar
sgfdotcom
Originally Posted by skratch
negative ghost rider. the security does not stop the fuel pump from coming on, so it sounds like you have something else going on there. check your maxifuse.
and if you don't know how, definitely learn how to use the manual override on the security. what if you are out in the middle of nowhere and lose your fob? better to punch in a few numbers and go on about your business than it is to get towed somewhere.
you seem to know whats goin on with these things, i noticed yesterday when fob battry was problem with security system, the fuel pump would run when switch was turned on, once i fixed security issue ...voila no more fuel pump...WTF... i dont have manual to lookup manual override , but in agreeance with u , i do need to learn how to override security , but dont believe that security is the issue here
Old Aug 1, 2010 | 03:52 PM
sgfdotcom's Avatar
sgfdotcom
Originally Posted by jdreed520
Yes if the pump is not coming on it is security, I would double check your fob battery, also pull the main and let it sit for a few min.
tks jd
Old Aug 1, 2010 | 03:53 PM
sgfdotcom's Avatar
sgfdotcom
Originally Posted by humpdebump
Make sure you have battery in correct, I replaced mine and had same thing happen until someone mentioned it to me, felt like an idiot. But yours could be different.
battry in properly
Old Aug 1, 2010 | 03:54 PM
sgfdotcom's Avatar
sgfdotcom
Originally Posted by 18BKLR
Try to over ride the system with your PIN. I think they are set at all 1's from the factory. Go through the owners manual and read on how to do it. I am thinking it is the security that is causing the no start.
i wish i had a manual
Old Aug 1, 2010 | 04:28 PM
sgfdotcom's Avatar
sgfdotcom
all fuses good and repositioned within each cavity....no power to or thru fuel pump fuse when ign turned on
Old Aug 1, 2010 | 04:38 PM
UltraJim's Avatar
UltraJim
Check the kill switch?
Old Aug 1, 2010 | 04:49 PM
sgfdotcom's Avatar
sgfdotcom
will check electrically when i get it pulled off and get my dvom thanks
Old Aug 1, 2010 | 05:29 PM
IBHarley's Avatar
IBHarley
did you check the wiring to the fuel pump if everything works except the fuel pump maybe its bad
Vabeacheric
Feb 28, 2017 05:57 PM
Rugboy
Sep 19, 2013 03:53 PM
bswearingen
Jun 12, 2011 08:18 PM
fcimino972
Jan 22, 2011 08:04 AM
lionpride1985
Jun 18, 2009 10:19 PM
