aftermarket stereo installation questions
Old Aug 7, 2010 | 04:53 PM
Gigantor's Avatar
Gigantor
Default aftermarket stereo installation questions
im replacing my factory deck on a 04 ultra with an alpine deck and was wondering if the resident gurus on here could give me an idea on what harnesses and connectors ill need to get for my installer. also is there a kit ill need to get to have the new deck fit correctly? ill be getting rid of the cb and intercom and want to keep hand controls the same as stock. i see biketronics have some kits but id like to get some info on which one/s i might need. any help is appreciated.
Old Aug 7, 2010 | 06:05 PM
tj316's Avatar
tj316
I used the hawg wired, added their amp and speakers too, love the sound
Old Aug 7, 2010 | 06:07 PM
Turbo Turtle's Avatar
Turbo Turtle
I bet if you get hold of Biketronics, they could tell you what you need.
After all, your probably going to order parts from them.
If I ever install a stereo, it will be an Alpine! I'll accept no substitutes
Old Aug 7, 2010 | 06:34 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
We can get either one, but sell a lot more of the Biketronics kits. Email Shawn at info@drvtwin for pricing please.
Thanks!
Drew
Old Aug 7, 2010 | 07:56 PM
PhatTerry's Avatar
PhatTerry
BT 1005 is what you'd need, we have it here in stock ready to ship if you're looking for a place to purchase.
http://www.phatperformanceparts.com/...ICS%2DRETRADIO
Old Aug 8, 2010 | 12:45 AM
GLACIERPEARL's Avatar
GLACIERPEARL
Did BIKETRONICS kit on my custom set-up !!
Old Aug 8, 2010 | 06:06 AM
andyp's Avatar
andyp
I have got an 04 flht with a Biketronics setup.I highly recomend a Marine head unit.First for the water damage and second for seeing display in sunlite. I like biketronics better mainly because they are the only one I know of offering AVC and their customer support is second to none.I have an Alpine 9886m marine head unit with an Alpine 45 watt plug in amp ($100) hertz 6.5 in speakers,hogtunes tweeter pod.Anuyways this is plenty for me.I could have spent more and bought a more powerful amp,but I DONT NEED IT.
Old Aug 8, 2010 | 11:22 AM
Harleypingman's Avatar
Harleypingman
On the first page of the Touring forum is a "sticky" for Biketronics installation. It's very thorough with lots of pictures. Although it's for a newer model year, your installation will be virtually identical, so it should be helpful.
The Biketronics and Hawg-wired interface modules (necessary to have handlebar controls of the head unit) plug in between the bike's Base Audio Connector (a 23-wire connector) and the head unit. So there is no additional wiring harness required.
Since you have an Ultra, the rear speaker signal is carried to the speakers by the Ultra connector (a separate 23-wire connector) plugged into the back of the OEM radio on the top left (rider's perspective) of the radio.
To have the rear speakers connected to the Alpine head unit, those speaker wires need to be removed from the Ultra connector, or simply cut off and connected to the +/- posts of the rear speaker outputs of the Alpine head unit.
The rear speaker wires needed from the Ultra connector are from the numbered chambers of the connector:
#3--Left rear (-), white/brown;
#4--Right rear (-), Light Green/Brown;
#10--Left rear (+), Brown; and,
#11--Right rear (+), Greeen.
Good luck with your project.
Carl
glenprice25401
Audio Systems
Apr 30, 2019 01:43 PM
electra_boogaloo
Audio Systems
Jun 29, 2017 08:43 PM
Crimson
Audio Systems
Jan 2, 2015 10:04 AM
kramercars
Audio Systems
May 21, 2013 11:42 PM
bmcgc
Jul 16, 2011 09:22 AM
