Vibration after exhaust install
Old Aug 10, 2010 | 01:53 PM
Lucky1958's Avatar
Lucky1958
Default Vibration after exhaust install
I installed v&h dresser duels and monster rounds then had a tuner done.
2-3k rpm the thing has a buzz in the bars and floorboards. I have pulled and reinstalled and run without heat shields. still buzzes.
V&H says this is normal do to a change in the system???
I say thats BS
Help
Lucky
Old Aug 10, 2010 | 02:07 PM
All Aces's Avatar
All Aces
Make sure none of the bolts are touching the frame. It happened to me. Keep in mind it may not touch when you are off the bike but does when you are. It may also only touch when you are on the throttle since the torque may make the bike sqwat down and may go away once you are upto speed. Just a thought.
Old Aug 10, 2010 | 02:15 PM
Lucky1958's Avatar
Lucky1958
I will recheck under load. great idea
Old Aug 10, 2010 | 09:24 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i had a cover clamp do exactley that had some clearence but under load it buzzed on the tranny cover.
goldie
Dec 5, 2021 04:17 PM
sel53
Aug 24, 2014 07:18 PM
kyle31490
Exhaust System Topics
Jun 11, 2014 09:33 PM
twhill3
Mar 3, 2009 06:16 AM
whylee
Jul 21, 2007 07:01 PM
