accessory fuse
Old Aug 11, 2010 | 11:56 PM
jgcable's Avatar
jgcable
Originally Posted by mblack7787
Harleycax, you definately have a fuse issue. You are correct, it is the ACCESSORY fuse. Where it is located on your paticular model< I am not sure. had the same thing happen to me recently on my 07 EG. Definately not a bulb issue, most likely not a short unless you have done some type of work to cause. Do yourself a favor and check the ACC fuse.
Sorry, this is not true. There is no accessory fuse that controls the signals. Actually, there is no accessory fuse at all.
The only true glass or blade fuses on a 1990FLHTCU are for the radio power, the CB/Intercom feed. They are under the fairing and are glass fuses. There are blade fuses under the clutch side side cover. They are for the CB power, and for external accessories that you might add like auxillary lights.
An 07 EG shares virtually nothing with a 1990 FLHTCU except for the fact that its a Harley Davidson Motorcycle.
Teddy1983
Apr 3, 2017 12:42 AM
Hortacious@gmail.com
Mar 23, 2017 09:30 AM
Cap'n Parrothead
Electrical/Lighting/Alarm
Jun 28, 2013 08:42 AM
King_O_Road
Jul 9, 2011 08:07 PM
DosDiablos
Jul 18, 2009 07:55 PM
