Steering Head Adjustment
Old Sep 3, 2006 | 09:53 PM
gliderman's Avatar
gliderman
Default Steering Head Adjustment
Checked my steering head adjustment as per the service manual. I do not get the 3 turns that the manual calls for. Mine goes full right then back to center and settles there. According to the manual it should go full right, then left, then back to center area. Is this something that I need to correct, or is it close enough??
Old Sep 3, 2006 | 10:05 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Steering Head Adjustment
That sounds like the front is still assembled together......
That is wayyyyyyyyyyyyy too tight (Providing that you did all that the manual calls for [Front tire slightly off ground with bike level, Outer Fairing, Clutch cable, Stereo removed)]..... Batwing Fairing I presume....
If that is the case, and it is in fact that tight, loosen the lower pinch bolts, loosen the stem nut (Make sure that you have a NEW Lock Tab at reassy), and take about 3-5 notches out of the starwheel adjustment......
Retorque Stem nut to spec... That will get you alot closer to your 3 swings (I like 2 3/4 - 3)...
Lube it up then also....
Old Sep 4, 2006 | 01:34 PM
gliderman's Avatar
gliderman
Thanks for the help. I appreciate it.............
Gwaxley
2014-2024 Touring Models
Jun 26, 2018 09:00 PM
danzio
Jun 19, 2013 11:35 PM
karlkcfi
Dec 24, 2012 09:50 PM
rkoivisto
Mar 13, 2010 05:16 PM
carltex
Jul 2, 2008 09:22 PM
