exhaust gaskets?
Old Aug 14, 2010 | 07:00 AM
frenchbiker's Avatar
frenchbiker
Originally Posted by TheDon81
I did not get any gaskets with my dresser dual and the directions said you can reuse the old ones if I recall correctly, I got the screaming eagle gaskets just to be safe.
I have the directions for the Dresser Duals in front of me and they say (as they should) to use the gaskets supplied (step 16). The 2 gaskets were in the bag with the mounting HW and fasteners.
It's not recommended to reuse exhaust gaskets. It's a recipe for leaks.
Regular HD gaskets are good enough but if you prefer the SE ones, so be it.
Old Aug 14, 2010 | 07:13 AM
StonerGlide's Avatar
StonerGlide
Can't remember if the gaskets came with my Dresser Duals or not but I went with the SE ones anyway, were not to pricey and worked good.
Old Aug 14, 2010 | 07:16 AM
2WheelGlider's Avatar
2WheelGlider
My True Duals came with new gaskets, just put them on less than 60 days ago.
Old Aug 14, 2010 | 07:23 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Originally Posted by tx-skydiver
My scoot has only 300 miles on it and I probably could have gotten away with reusing the original gaskets, but I bought new ones from HD and used those instead. Then I find tewo more in the D&D box. Oh well...
HT silicone??? I did not use this on mine and saw no resemblance of it on originals. How important is this? Don
t mean to hijack, but it could be good info for OP as well.
I was also wondering about the silicone. I didn't use it with the slip-ons
Old Aug 14, 2010 | 07:35 AM
StonerGlide
Yea use the high temp at the slip-on joint it will make a difference.
Pre fit the muffler and then put a bead inside the slip-on and smear a layer just behind where the joint will overlap. The two layers will join and make a good seal.
Was worth it to me anyway no leaks at all.
Old Aug 14, 2010 | 07:45 AM
Iceman24's Avatar
Iceman24
You want to ensure a good seal between the header & pipes b/c this joint is prone to leaking if not properly seated (positioning, tightness & stability). Using the high-temp (copper) silicone will ensure you don't get any of those annoying hissing leaks at the pipe/header connection which will also cause decel popping too.
Old Aug 14, 2010 | 07:50 AM
StonerGlide
^ Yeah, what he said.
Ain't had enough coffee to get that technical yet this morning
Old Aug 14, 2010 | 08:42 AM
frenchbiker
High temp RTV is a must if the muffler goes inside the head pipe and if the muffler goes over the head pipe, it won't hurt. In both cases, it makes the installation easier and will prevent leaks.
Old Aug 14, 2010 | 10:31 PM
gman116's Avatar
gman116
Put new V&H Dresser Duals on my bike last week (ordered through Fuel Moto). No gaskets. The instructions recommended the part number for the SE gaskets or the part number for V&H gaskets. I went with SE gaskets. No problems so far.
Old Aug 14, 2010 | 10:35 PM
soft 02's Avatar
soft 02
I must be lucky. I didnt get any gaskets with mine. I just left the originals in there and that was 70,000 miles ago plus I've had them off several times.
