09 headlight circuit
Any electrical experts out there who can decipher the diagram for an amateur and give their opinion?
thank you
I've never seen any evidence of wire or connector deterioration on either bike. I put 106k miles on the RK and the SG now has 37k. I will say that two friends, one with a '98 Softail and the other with a BMW GS, had trouble with connectors related to heat using these bulbs. Both replaced the stock connector with a high-heat connector they bought at Auto-Zone and to my knowledge didn't have any more problems.
This also takes all the main load off the handlebar switches and contacts and stock wiring.
The stock wiring would then just "trigger" the relay with a small load and the relay would provide full power to the lamp through it's "own" larger wired circuit.
This guy provides a really neat setup , which I will do this winter on mine.
http://www.easternbeaver.com/Main/Pr...s/h4_kits.html
The H4 single headlight relay kit makes this really easy to do yourself and should make the circuit more or less bulletproof (and efficient).
The power wires are 14 gauge and plenty large enough to power any headlight bulb you choose.
This would provide a noticeable improvement even with the stock 55/60 bulb.
I run a 70/65 Osram , which really lights things up well at night.
Take some time and read what he's got , I emailed him and he seems like a straight shooter and has some great feedback and well designed stuff to offer.
Mick
