HD Oil
Old Aug 28, 2010 | 09:53 AM
  #31
VETERAN75's Avatar
VETERAN75
I was talking to a indy mechanic 2 weeks ago about bikes and things. I asked him about transmission oil and the clunk when placing in 1st gear. He's been working on them for 42 yrs, he used to build and run a prodrag program. He said he prefers belray in the transmission but the redline is good also. He says the clunk will be there pretty much no matter what because of the design of the clutchplates. He also said they were a gm product design and said I should use dexron atf in the primary. He recommends amsoil 60 for the engine year round. He started out working for a dealership and said they are just makin money on their formula+. I have read here at other times where some are using the atf in the primary. I will give it a try when I change it next. They guy had over 140,000 miles on his ultra so it can't be too bad. That's my tidbit.
Old Aug 28, 2010 | 09:58 AM
  #32
skratch's Avatar
skratch
Originally Posted by Bearcat1
Mainly because charging some $13 per quart for Syn 3 from a Harley dealer is a huge ripoff. Especially when you can go buy Mobil 1 V-twin 20w-50 at your local auto store for around $9 a quart.
if your dealer charges that much for syn3, he is definitely ripping you off. msrp is $10.49.
personally, i use 15/50 mobil1 for $21.00 for 5 qts.....
just sayin......
Old Aug 28, 2010 | 10:07 AM
  #33
Dionicio's Avatar
Dionicio
Old school here. Been using HD dino since the 60's. No oil related problems, ever!
Old Aug 28, 2010 | 10:33 AM
  #34
cezariomaia's Avatar
cezariomaia
Here in Brazil, Harley dealers uses Motul 5100 in the motor, and god knows what in the transmission and gear box...
Old Aug 29, 2010 | 06:48 AM
  #35
Port Dawg's Avatar
Port Dawg
Originally Posted by V2Evo96
That and the fact that your hard earned $$$ in part goes back to the dictator Chavez in Venezuela via CITGO, the Venezuelan oil company who presently holds the contract to produce lubes for HD.
Thought Sunoco now produces oil for Harley
Dawg
Boxer 6
Sep 11, 2013 11:28 AM
jiminpa
Oil Archive (no new posts)
May 15, 2012 09:06 AM
bergluke
Nov 4, 2009 06:52 AM
twincam47
31
Apr 8, 2008 07:19 AM
young fellow
Jan 18, 2008 08:21 PM
