Another Exhaust Question
Old Aug 28, 2010 | 06:57 PM
bks's Avatar
bks
Default Another Exhaust Question
I picked up my 2011 Ultra Limited this moring. I've been reading up on all of the exhuast options and right side heat issues for the past couple of weeks. I know getting rid of the cat and the stock mufflers is will allow it to breathe better and I plan on doing it a little later on. But for now, I was wondering to help with the heat from the cat on the right side has anyone tried removing the heat shields and wrapping the head pipe and cat area with header wrap and then re-installing the heat shields? Or is the room between the pipe and heat shields for this?
Old Aug 28, 2010 | 07:14 PM
TitoFTW's Avatar
TitoFTW
Originally Posted by bks
I picked up my 2001 Ultra Limited this moring. I've been reading up on all of the exhuast options and right side heat issues for the past couple of weeks. I know getting rid of the cat and the stock mufflers is will allow it to breathe better and I plan on doing it a little later on. But for now, I was wondering to help with the heat from the cat on the right side has anyone tried removing the heat shields and wrapping the head pipe and cat area with header wrap and then re-installing the heat shields? Or is the room between the pipe and heat shields for this?
I think you made a typo somewhere. 01 Ultra Limited???? Ummm......
Old Aug 28, 2010 | 07:52 PM
bks's Avatar
bks
Sorry, I meant 2011. I fixed it.
Old Aug 28, 2010 | 08:07 PM
TitoFTW's Avatar
TitoFTW
Ha-ha. Hey, that was my "Huh?" moment for the day.
Old Aug 28, 2010 | 08:13 PM
whitetruk's Avatar
whitetruk
second day with my 2011 limited,love it.
it is a little warmer on the right side of my leg,so i put my foot on the hihgway peg,works for me.
i also put jackpots new slip-on on.
Old Aug 28, 2010 | 08:24 PM
seph10's Avatar
seph10
I have a 2009 ultra classic, I put on a k&n air filter, powermaster slip-on's with 2" baffels and a V&H fuel-pak, setup the fuel-pak as instructed by the floks at V&H,,the bike runs great,,sounds good too,,now all I have to do is just ride,,
Old Aug 29, 2010 | 03:21 AM
Watch Guy's Avatar
Watch Guy
Default I just installed the V&H Power Duals and
the heat issue from the cat on the right side is gone.
Old Aug 29, 2010 | 07:48 AM
bks's Avatar
bks
I understand that making any of the above changes will help, and I plan on making them a little later on when I decide what I want to put on mine. But for now I was wondering about wrapping them to help with the heat short term. Anybody???
Old Aug 29, 2010 | 08:03 AM
Iceman24's Avatar
Iceman24
Never tried heat wrap, but you'll want ample space between pipe & outer shield. Adding a layer of wrap will probably make it too thick to function properly. Also, if you wrap the pipe, the shields shouldn't be needed - right? The wrap is designed for use instead of heat shield(s). Might be worth a try, but why not start saving this cash for your replacement exhaust & go that route. You'll want to keep the old header/pipes in case they're needed later. Good luck!
Old Aug 29, 2010 | 09:18 AM
roadgliderick's Avatar
roadgliderick
change the head pipes thats a start.
nivensid
Touring Parts
Feb 21, 2013 07:10 PM
olsenjb
Jun 20, 2012 07:20 AM
Yasky1997
Feb 27, 2012 09:49 PM
Bfazona
Touring Parts
Nov 29, 2010 06:51 PM
rocksandgiz
Mar 9, 2008 07:24 PM
