Stage 1
Old Aug 29, 2010 | 10:35 AM
aviator's Avatar
aviator
oh, ok. I don't have any experience with baggers with cats. so, maybe so. I was speaking of my own experience with a 96B engine.
Old Aug 29, 2010 | 01:05 PM
nutsandbolts5212's Avatar
nutsandbolts5212
SIU 96 you are correct, but you left out the fuel management system you have installed and how well it's tuned. This is why your bike ran worse than stock. A Fuel management system adds more fuel to the mix, since the bike's are lean to begin with stock.
To the OP, IMHO, if money isn't too much a problem, go with a new exhaust system,(no slip ons),new performance a/c, and a fuel management setup. Do your homework and for your tourer this will be all you need until you start chasing #'s. Ride on and ride safe!
Old Aug 29, 2010 | 01:49 PM
KutenFLHX's Avatar
KutenFLHX
I did a stage 1 on my SG. Went with V&H power duals, Rinehart 4" slip-ons, Fuel Moto SE air cleaner and power commander V tuner. Got it all from Fuel Moto for a great price and was relatively easy to install.
Old Aug 29, 2010 | 03:51 PM
Mike's Avatar
Mike
Here's how I look at stage I. It's just my opinion, which might be diffferent than someone else's.
Stage I is kind of an interchangeable term. There's a stage I air cleaner, a stage I download, and a stage I upgrade, which generally entails air cleaner, exhaust, and fuel upgrades. Back when we ran carbureted bikes, a stage I fuel upgrade involved re-jetting. A "stage I" bike would include all three.
The stage I download apparantly only raises the rev limiter. But on O2 sensor equipped bikes in closed loop, the ECM will adapt for air cleaner and mufflers, and add fuel. Of course, it's only adding enough fuel to get the bike back to the AFR set by the factory, which is too lean for most of us. Still and all, if you've gone to a free flowing air cleaner, exhaust and the ECM is adding fuel, it's still considered a full stage I upgrade.
In order to address the heat problem, and get the bike running properly, you need to add even more fuel. That's generally done with a fuel management device, such as a Power Commander, fuelpak, SERT, etc.
Lots of guys consider a stage I upgrade with fuel management upgrades to be the minimum upgrade necessary to get the bike running properly.
brokefootkenny
2014-2024 Touring Models
15
Sep 1, 2017 10:32 AM
zipp0
40
Apr 18, 2014 03:21 PM
TN 0208
May 25, 2012 06:36 PM
DC2009EGUC
Nov 22, 2008 11:07 AM
dmhosting
Apr 9, 2007 12:38 PM
