Need some help here please
Old Aug 31, 2010 | 09:54 AM
slojoh's Avatar
slojoh
Default Need some help here please
I have a tourpack off a 2006 street glide. I have a 2011 street glide. I know this wont fit the 2011, but i am wondering if i get the docking hardware and the detatchable hardware if it will bolt onto the 06 tourpack. Is the bolt pattern the same. If not any ideas appreciated. thanks
Old Aug 31, 2010 | 10:00 AM
bennenrkc's Avatar
bennenrkc
I believe the bolt pattern is the same, at least on my tourpak that I bought last year I could make it fit several different mounting styles.
Old Aug 31, 2010 | 11:14 AM
dstahl's Avatar
dstahl
Default tour pack mounts
I moved my chopped tour pack from a '07 to a '10.
I had to have new holes drilled for the mounting bracket.
It also needed a spaced added to the bottom of the tour pack.
Harleypingman's Avatar
Harleypingman
The pre-drilled mounting holes in the '06 tour pak won't line up with the holes in an '09 detachable rack (or the the rigid mount found on EG Classics or Ultras which are the same as the detach rack).
Use the holes in the '09 and newer detachable rack as a template to drill holes in the '06 tour pak bottom and you'll be able to reuse the '06 tour pak on your new bike.
Take a tape measure to a buddy's '09 or newer tour pak, or go by a dealer and measure from the front of the tour pak to the forward mounting holes in the tour pak so you will know where to put the rack on the bottom of the '06 tour pak for drilling the holes.
Good luck with your project.
Carl
2009streetglide
Mar 21, 2013 06:13 PM
Strick120
Sep 4, 2011 06:38 AM
John Schleifer
Mar 4, 2011 07:51 PM
OldTimer
Apr 7, 2010 09:10 AM
hillbily
Jan 18, 2010 09:27 AM
