GPS Wired
Old Aug 31, 2010 | 04:15 PM
oricko's Avatar
oricko
Default GPS Wired
Ok I bought a cable to hard wire gps to bike. Once i was done I now get static on radio when gps is on. I have a hidden antenna. My question is can i cut the charging block out of gps wire harness, I am thinking it might interfere with radio. Does it need charging block????
Old Aug 31, 2010 | 05:01 PM
KutenFLHX's Avatar
KutenFLHX
What GPS do you have? What wire harness did you get for it? Depends on how you wired it in. Make sure you did not run the power lines near the antenna. It could also be that the bluetooth signal from your gps (if it has it) is interfering with your antenna (if so, try turning the bluetooth off).
Dalton
Oct 15, 2017 06:24 AM
Indy Road Dog
May 24, 2012 08:26 AM
NoChute
Mar 3, 2012 11:04 AM
Ultra Rider 07
May 25, 2011 10:01 AM
sweet street glide
Jan 11, 2008 08:02 PM
