marcparnes ignition switch tool
Old Sep 1, 2010 | 11:15 PM
iclick's Avatar
iclick
Originally Posted by Max96
Nice tool.. like any normal guy I LOVE new tools. Question I have... is this tool necessary? I have had my ignition switch out/back in a few times already, and have not had any issues. Maybe I just got lucky?
I also wonder why you need it. If you need to remove the ignition switch you're not likely to change the orientation of the switch while you're disassembled. If you do you can reinstall the ****/shaft with washers and nut in place and move it without getting the tumblers out of whack. Even if you botch the tumbler positions, which I did once, you can get them back in order with a screwdriver. His tool would make the latter operation easier, but it is unlikely you'd get in that position.
Old Sep 1, 2010 | 11:32 PM
V2Evo96's Avatar
V2Evo96
Some tools just look good, are easy to use, and are nice to have on hand even if rarely needed. This is one of them IMHO.
Old Sep 2, 2010 | 01:38 AM
Turbo Turtle's Avatar
Turbo Turtle
Their wheel balancer has now moved to the top of my list for new tools. I've always wanted to be able to do this. And for a reputable price.
$25.00 is a pretty right price for the switch tool. Do they screw up regularly enough for me to have or want to do it myself?
Old Sep 2, 2010 | 02:43 AM
bluewind's Avatar
bluewind
I made mine out of 1/4in copper tubing found how to make it right on H.D.i think it`s in diy section he has a video of how to remove the switch save your bucks.
Old Sep 2, 2010 | 07:38 AM
silverbullitt's Avatar
silverbullitt
No, it isn't necessary, but if you get one out of "time" it sure makes it easy to fix. Plus, it just looks "professional". I thought about making the copper tubing one, then I saw the picture of Marc's piece, so I sent him a PM. I thought it would be real expensive, but when I saw that it was a mere $25.00, I had to have it.
Old Sep 2, 2010 | 07:58 AM
twodollarbill's Avatar
twodollarbill
Sweet Deal
If you have ever over rotated and locked up your front end or messed up your lock while working on your bike,
you'll be glad you had one or........ just **** and complain like 99% of all Harley owners.
Old Sep 2, 2010 | 09:04 AM
silverbullitt
Yeah, the video is really nice. The guy did a good job of explaining it, so even a DA like me understood it!!
Old Sep 2, 2010 | 11:41 AM
iclick's Avatar
iclick
If you want to change your own tires, there's really no need to buy the HF tire changer. Lately we've been using tire spoons instead and just doing it by hand. The tire changer requires you to remove a rotor or pulley, which we got tired of doing, and although it's a wrestling match with the spoons we always win. It's kind of fun, actually. We use cut-up milk cartons and plastic car floor mats to protect the rim, as well as rim protectors, RuGlide or facsimile (required!), and an air compressor with direct connection (i.e. no tire chuck) to seal the bead and inflate the tire. After you do it a few times it becomes easy and forthright.
Find a few friends and start a collective, and when someone needs a new tire we get together and have a tire rodeo.
Old Sep 2, 2010 | 11:43 AM
iclick's Avatar
iclick
Originally Posted by twodollarbill
Sweet Deal
Or, just use a screwdriver to get it back in-whack. Then remember how you got it out-of-whack and don't do it again. It's really quite easy to work on that area without screwing up the tumblers.
Old Sep 2, 2010 | 01:39 PM
silverbullitt
You are right, but I have the worst luck of anyone in the world. It it can happen, it happens to me. Most things go real smooth, but then there is that one time..........
