All I want
Old Sep 2, 2010 | 03:24 PM
blusmbl's Avatar
blusmbl
My stock 103 pulled the front wheel a couple inches when I was horsing around in a parking lot learning some of it's low speed characteristics. I don't have any doubts that a small gearing change on a stage 1 96 will get you there, all it takes is either being willing to clutch it up or precise throttle control.
I've wheelied lots of dirtbikes, and did smaller ones (not at balance point) with my Hayabusa, but I can't imagine it's easy to set down the front end of a bagger gently. Be careful, you'll be blowing out fork seals.
Old Sep 2, 2010 | 04:32 PM
thecort's Avatar
thecort
Get back on the seat or passenger seat (if you can reach) then rev it up & pop that clutch...Ouch! on the front end. It'll take some practice but you'll get it (maybe not 12 O'clock), but you'll get it. Good luck & be careful!
Old Sep 2, 2010 | 05:52 PM
UltraClassicElectraGlide's Avatar
Here's a few of my wheelie favorites; first one the bike just gets a away from him, but he couldn't control it after the front wheel got out of shape;
http://www.youtube.com/watch?v=TEBCTIlfMow
Second one is a wheelie, but looks like water and a short stopping distance don't mix.
http://www.youtube.com/watch?v=MIP1h...eature=related
This guy has it dialed in.
http://www.youtube.com/watch?v=wDiDc...eature=related
This guy too.
http://www.youtube.com/watch?v=luq4w...1&feature=fvwp
Old Sep 2, 2010 | 06:01 PM
blusmbl's Avatar
blusmbl
You're forgetting the lack of riding talent.
Old Sep 2, 2010 | 06:53 PM
dirtydon's Avatar
dirtydon
07 stock ultra no passenger 8 in little wheely. easy,little throttle rolling first gearnail gas comes up.little but comes up
Old Sep 2, 2010 | 07:18 PM
Raaze07's Avatar
Raaze07
Those videos are pretty crazy, in some of them it sounds like the riders are shifting while they've got the front wheel up - i didn't even know that was possible while you're doing a wheelie?
Old Sep 2, 2010 | 07:49 PM
ironhead3fan's Avatar
ironhead3fan
don't think I ever want to be that good
blusmbl's Avatar
blusmbl
If you're at the balance point pretty much anything is possible. I've seen a famous motocross racer pull the front end up, cut the engine off, and ride an eigth mile with the engine completely off and the front end in the air before he ran out of momentum and stopped.
Old Sep 2, 2010 | 07:57 PM
thecort's Avatar
thecort
I originally started riding sportbikes about 20yrs ago (geez I feel old!). My friends & I used to wheelie quite a bit, even at triple digit speeds! Lots of practice. The only way to get to those speeds is by shifting while you're doing a wheely. I used to shift from 1st to 2nd just when the front tire started to come up (& so on). Gotta be quick & smooth. There are all different types of techniques...It's a lot of fun!
Old Sep 2, 2010 | 08:39 PM
nvsteve's Avatar
nvsteve
Originally Posted by nutsandbolts5212
You want to adjust your gearing for low end torque, and you WILL pop wheelies all day long. Try a 24 tooth. I don't think messing with the heads or cams is really necessary. Be careful!
I don't think so on his bike. Stock primary is front 37, I think. Front belt sprocket is 32.
