Cleaning Air Filter
Old Sep 2, 2010 | 08:12 PM
bayoun1's Avatar
bayoun1
Default Cleaning Air Filter
Any suggestions for cleaning an air filter... or should I just replace it with a new?
Old Sep 2, 2010 | 08:17 PM
Ronp42's Avatar
Ronp42
Account Retired
What brand of a/f? Is it a K&N stage 1? If it is, they have a cleaning and reoiling kit you can buy. I have the Arlen Ness Big Sucker. It's the same kind as K&N. I spray it around the outside with the cleaner, let it soak fo a few minutes and rinse with water from the faucet from the inside out. I lay it on my floor fan in the garage and let it dry. Reoil with the recharge oil and reinstall. Simple!!
Old Sep 2, 2010 | 08:19 PM
Ronp42's Avatar
Ronp42
Account Retired
Forgot to add, if it's a SE stage 1 A/F that you don't oil, I would wash it with warm water and diswashing detergent. Let it dry and reinstall. Hope this helps!
Old Sep 2, 2010 | 08:23 PM
bayoun1's Avatar
bayoun1
Sorry...should have stated it's a stock air filter element 29633-08 for a 2010 103 Limited.
Old Sep 2, 2010 | 08:31 PM
stev394's Avatar
stev394
Default Air Filter
Stock does not require oiling...Depending on how dirty it is you can either use compressed air to blow it out from the insode out or you can use warm soapy water and aloow to completely air dry before reinstall
Old Sep 2, 2010 | 08:38 PM
Ronp42's Avatar
Ronp42
Account Retired
I didn't think you cleaned a stock filter, thought they had to be replaced. I know you are not supposed to use compressed air to blow them out. Says so right on the instructions that comes with all cleanable filters. Blowing with compressed air can damage the element...just saying!
Old Sep 2, 2010 | 08:49 PM
stev394's Avatar
stev394
Default Air filter
The stock paper filters are cleanable...Using an air comp at low psi does a great job for minor cleaning but warm water and air dry cleans em up well replace as needed
Old Nov 23, 2010 | 05:43 AM
troop's Avatar
troop
The search button was my friend. This was a question I was just going to post for my Ventialtor intake
Old Nov 23, 2010 | 05:53 AM
smat45's Avatar
smat45
to 'dry' it i put a bolt thru the hole and spin it on my cordless drill for a quick minute...works great...just make sure to spin it in a safe area where the lil bit of water will fly...
smat
Old Nov 23, 2010 | 06:12 AM
ericl's Avatar
ericl
smat
now thats cool
