Transmission noise - knocking sound
Old May 17, 2012 | 08:04 PM
FX4's Avatar
FX4
Mine does it, I actually complained about it going down the Interstate and the tech found it at idle. He said the only thing you can do is rebuild the transmission and he said it won't hurt anything, ride it until it breaks. That was 17,000 miles ago.
Old May 17, 2012 | 08:20 PM
btsom's Avatar
btsom
I wonder if the primary chain is a bit slack and as the slack is taken up and then released it slams the transmission from drive to coast and back again. What you hear is coming from the transmission but caused by the primary-just a wild guess.
Old May 18, 2012 | 06:34 AM
jeffRKMC's Avatar
jeffRKMC
Default Neutral rattle
I understand a "neutral rattle" but when you are riding , this so called rattle shouldn't be noticible.. It goes away , mostly, after the drive train is hot.. It does it under load and appears not to be lifters since I can sit in the driveway and rev the motor and there is no valve noise.. It is a KNOCK and is noticible and loud at 2500 up to 3000 rpm.. I guess two more times into the dealer and the lemon law kicks in !!!!!!
Old May 18, 2012 | 07:00 AM
1flhtk4me's Avatar
1flhtk4me
Take it to another dealer.
Old May 18, 2012 | 07:44 AM
blusmbl's Avatar
blusmbl
Originally Posted by g money
https://www.hdforums.com/forum/touri...al-rattle.html
It is normal and has been discussed here at length. Click on the above.
Yep. Trying different fluids changes the noise somewhat, but it's normal. It's a v-twin that isn't smooth, you can't expect it to sound like a Honda.
Old May 18, 2012 | 07:56 AM
FlamedFXR's Avatar
FlamedFXR
Lemon Law requires that there is actually something broke that they cant fix.
Also....when you dredge up an old thread your issues get confused with the original post
Old May 18, 2012 | 08:03 AM
FX4's Avatar
FX4
That was my complaint. It still does it good and hot. If you dig around there are a lot of guys that complain about this. The only thing I can tell you is it has not broken in a lot of miles for me. Under load load it kind of sounds like a wood mallet is hitting the clutch cover. I now just consider it the nature of the beast. These Harleys make a lot of strange noises. Most of them mean exactly nothing.
Old Jun 2, 2012 | 09:27 AM
jeffRKMC's Avatar
jeffRKMC
Default Transmission noise
Here's what the Harley rep said who took it for a ride.. Harleys are not custom bikes but production bikes and the tolerances aren't like a custom ! Ride it !!... Now that is what the factory rep is told to tell us.. Sounds like crap to me !!!!!
Old Jun 2, 2012 | 12:06 PM
jeffRKMC's Avatar
jeffRKMC
Been thru a lemon law suit with Ford and beat them on dash rattles.. this is no difference.. Just gotta start the ball rolling to get their attention and find out what the problem is instead of everyone complaining...
Old Jun 9, 2016 | 02:28 PM
gprosperie's Avatar
gprosperie
Stage I
Originally Posted by davessworks
I took my bike in to the dealer today and one of their techs took a look at it. They heard what I've heard for some time now - a knocking sound coming from in the transmission.
The tech suggested I not worry about it - "it's the shifter dogs knocking while the bike's in neutral"
Anyone ever hear of this before? I've been riding Harley's for 20 years and never heard this noise before. Good news - I still have 14 months of warranty left but . . .
I have had the same problem, I had a second opinion and I was told to put a heavier oil in the transmission, done that today, ran bike till it got hot, seems to quiet n it up some, but sometimes there is a knocking sound when you throttle up or down, that comes from the design of the back wheel. There is a rubber gear in the back rim. Still don't like any noise coming from anywheres except my pipes. Was told it has become a normal screw up
