Rivet Tool?
Old Sep 4, 2010 | 12:47 PM
MickeyB's Avatar
MickeyB
Default Rivet Tool?
My friend has a '91 Ultra that has a broken saddlebag lid due to theft. He has a new painted and pinstriped lid that we need to install. The hinges and latches all use small rivets. The rivet heads sit flush with the hardware but we can't quite figure out what tool is used to mushroom the stems.
A call to the Harley dealerships was no help of course. Anything older than 5 yrs. and they deny any practical knowledge at all.
Any help appreciated,
Mike
Old Sep 4, 2010 | 01:01 PM
Pagan48's Avatar
Pagan48
Probably a driven solid rivet (not pop). THey come in dome head (universal) and flush head variety. A "bucking bar" and "rivet gun" are used to set these or a rivet squeezer. You can use a couple ballpeen hammers to set them but it is risky as it is easy to damage the surrounding material. Do a google search for setting aircraft rivets or setting solid rivets and it should give you some help. Looks like you're in Colorado or I may be able to help in person.
Pagan48 (Aircraft Mechanic)
Old Sep 4, 2010 | 01:16 PM
MickeyB's Avatar
MickeyB
Thanks for the reply. The way the ends are mushroomed out it has a hollow space in the middle which to me means they weren't bucked. I think you hit the nail on the head with "rivet squeezer." Now, just to find one!
Mike
Old Sep 4, 2010 | 01:20 PM
07FLHT's Avatar
07FLHT
I'm sure your dealer has the riveter... most here do & yes it is a speical one. Take the lid to the dealer & have them install the lid latch. Should'nt cost more than a few bucks, if any (my local dealer did mine free). Then get the premium hinges, they screw in instead of rivet and look better too.
Old Sep 4, 2010 | 03:32 PM
Harleypingman's Avatar
Harleypingman
+1 on what 07FLHT said. IIRC, the tool is a "blind" rivet tool and simply squeezes the rivet with a die of the appropriate size to mushroom the rivet. I had a tech at the local dealership do it for me; same type rivets are used for tour pak hinges and lid latch hardware.
Carl
Old Sep 4, 2010 | 04:33 PM
Peculierboy's Avatar
Peculierboy
I can confirm it's a rivet squeezer. If you wanted to buy the tool, it's about $175 or so. My dealer wouldn't put the rivets in when I rebuilt my tourpack after repainting it, and I really couldn't justify the cost, so I bought some Stainless Steel rivets that worked with a regular rivet gun. Looks great, and I really doubt you can tell they are not the blind rivets.
Old Sep 4, 2010 | 09:00 PM
tslonige's Avatar
tslonige
Would a 1/4" chicago screw work? They have them at True Value hardware in black or aluminum.
Old Sep 5, 2010 | 09:00 AM
katobird's Avatar
katobird
go to your local airport FBO (fixed base operator) that does aircraft maintenance...I'm sure someone will have no problem bucking a few rivets..
Or call one
Being in Aviation, I've helped quite a few people out for riveting needs...instead of buying
Old Apr 21, 2013 | 09:05 PM
FlyBD5's Avatar
FlyBD5
I know this is an old thread, but an aviation pop rivet will do. In another universe I use them to build BD-5J Microjets. LOL!
Old Apr 22, 2013 | 06:18 AM
alame's Avatar
alame
Or call one
squeeze it up with Knipex pliers, we do it all the time on helicopters, nice neat job with no effort
