ultra brake light problem
Old Sep 8, 2006 | 10:54 PM
gibbyair's Avatar
gibbyair
Default ultra brake light problem
. I recently installed new grips with glow caps. I had to open up the fairing to make these electric connections. I had both throttle and clutch assemblies open so to install the grips...now my cruise wont work. I’m assuming this is because I don’t have brake lights or my rear yellow running lights. Rear turn signals work front yellow running lights but the RT turn signal doesn’t.
Where do I start to fix rear brake lights? I have a feeling I need to start by checking my connections behind fairing. Any help will be greatly appreciated
Old Sep 8, 2006 | 11:37 PM
cutacroshorty's Avatar
cutacroshorty
Default RE: ultra brake light problem
You very likely pinched a wire while tightening the switch housing on the handlebars. If you removed the switch housing the process, try and loosen the screws up a bit.
Old Sep 8, 2006 | 11:39 PM
SMenasco's Avatar
SMenasco
I had trouble with my cruise dropping out and that's the first question I was asked on the phone by the shop manager, had I replaced the grips.
[IMG]local://upfiles/1638/10B5F87AB82D4D47A709BC8F51D2ABDA.jpg[/IMG]
Old Sep 11, 2006 | 01:25 PM
gibbyair's Avatar
gibbyair
I have been able to fix most of my light problems except now my front right turn signal is brighter than the left and it doesnt flash. when I turn it on the rear starts to flash normal then to a quick flash like the buld is burned out. other side works just fine
any help where I can start to fix this ?
i couldnt get the rear tail light to work so i took the rear lens cap off and moved the wires and bulb some what and it started working..that was kind of strange since I hadent touched anything in the rear
machm1969
Jan 10, 2013 10:23 AM
bmxatv
Apr 24, 2011 06:53 AM
scazelot
Jun 3, 2009 01:17 PM
PriestFan
Aug 2, 2007 07:09 AM
PriestFan
Jan 3, 2007 10:52 PM
