SERT with no data after dyno
Also a good dealer would give you a copy of the map they worked up for you.
Now, if no canned map matches your mods. You'll need the SE tuner to fine tune one of the canned maps or create one from scratch. That requires the Tuner and most likely a dyno to do all the adjusting of the map parameters.
It seems like the first dealer took a short cut and didn't use the your tuner to load a canned map. If he didn't charge you separately for it no harm done. But doing a dyno and tuning using a dyno are two entirely different things.
it. I took it in for its 5000k service and had it dynoed again. Not @ the same dealer and they told me that my tuner was blank and just running
on the default mode. I had taken the bike to Sturgis and coming back to Texas in went into the limp home mode for a while I think,but no codes were thrown. Is it possible to dyno a bike and have nothing on the sert
showing it was done? Current #'s are 82TQ and 72 HP. Any ideas?
I'd be looking for a knowledgeable guy to hook up the sert again and at least see if it recognizes the bike. If not, I'd want my sert money back.
You can not upload a map "from" your bike via sert (you can with power commander).
You can make new maps all day and download them to your bike, but no uploading from the bike with sert.
Did the sert "see" your VIN # ????? If so, you likely have no issues to worry about!
said their was no Vin# that showed up.
Did the sert "recognize" the bike when he hooked it up?
Was the VIN listed in one of the windows?
If so, I really don't think anything was wrong.
The guy may have been used to the Power Commander where you get to see the actual map that's loaded in the bike. SERT don't work like that.
If you want to make changes in a sert map, you have to have the original copy of the map, make your changes, then reload the map.
If you don't have the map, you have to "start from scratch" with a basic map, do a run and sniff the afr, make some changes to that map and reload it, do another run, sniff the afr, make some more changes, etc.
He can play with timing after viewing hp/tq lines and other info hidden in that wonderful program, too.
But you can't just hook it up to your bike and have a map to look at. Ain't gonna happen with sert. You can not "pull" a map from your bike.
EDIT: I see you edited your post to say it shows no VIN.
That is not a good sign. I honestly believe your original dealer has some financial liability here.
You paid for a tune that you may not have received. They need to redo, or show proof of what changes they made (a copy of the map they loaded would be excellent proof).
Also, you might not have the right unit. Might have got somebody elses by mistake. They only marry to one bike.
The first dealer needs to make it right.
that did it was not there, but they did tell me that they base it on a big bore with flat top pistons.
This sert is black in color it was the new one when I purchased it. the latest & greatest is orange and as I understand it will store the map in its memory.
