deep engine knock
Old Sep 19, 2010 | 10:03 AM
cdale976's Avatar
cdale976
Default deep engine knock
have an 2010 limited. bikes runs great. what concerns me is HD just put new download in ecm due to power lose when hot. Fixed problem fine but now after an extended run on the highway when the bikes comes to an idle there is a very clear deep knock at idle. If i shut bike off and restart it goes away. any ideas before i take it back to dealer??? anyone else have the same issue.
Old Nov 26, 2010 | 05:10 PM
Airmech's Avatar
Airmech
3rd Gear
Default Deep Knock
My 2011 Ultra Limited has the same knock exactly as you describe it. Dealer said it is normal.
I was even wondering if they really put SE compensator in mine.
Old Nov 26, 2010 | 05:58 PM
CigarCritic's Avatar
CigarCritic
Parade mode on?
Old Nov 26, 2010 | 08:53 PM
cdale976's Avatar
cdale976
No parade mode is off. now that the weather has cooled off i don't notice it nearly as mauch
Old Nov 26, 2010 | 09:47 PM
Teardrop's Avatar
Teardrop
Could it be the injectors?
Old Nov 26, 2010 | 10:41 PM
FDHOG's Avatar
FDHOG
My favorite phrase!
Old Nov 27, 2010 | 07:01 AM
Airmech's Avatar
Airmech
3rd Gear
I know, what a joke everything is normal to them. When I brought it in 2 Tech's came out to listen the knock was so clear but they still pretend they do not hear anything. It still does it even in this cold after a trip.
Old Nov 27, 2010 | 07:15 AM
Fathead2003's Avatar
Fathead2003
Sorry for your troubles. The dealers can really be a joke at times. Try an record your motor before and after to capture this clear deep knock.
Old Nov 27, 2010 | 07:21 AM
mattman22033's Avatar
mattman22033
Are you sure your parade mode is off?
My RGU does that same thing at idle sometimes and I assumed it was the parade mode. I just twist the throttle a bit and it stops...that's how I figured out it was parade mode thing.
Old Nov 27, 2010 | 07:27 AM
Airmech's Avatar
Airmech
3rd Gear
I will check if parade mode is off. Thanks
Old Bugger
Jul 10, 2017 07:03 AM
Caine01
Aug 23, 2015 02:23 PM
Bigbob88
Jun 22, 2012 03:30 PM
rootbeer bob
May 25, 2012 06:45 AM
97WG
Exhaust System Topics
Sep 6, 2010 07:46 PM
