For want of a nail the shoe was lost.
For want of a shoe the horse was lost.
For want of a horse the rider was lost.
For want of a rider the battle was lost.
For want of a battle the kingdom was lost.
And all for the want of a horseshoe nail.
Now your next noise will be that screw razzing on something where it's hiding!
LOL! Maybe! I still haven't found the screw on the floor anywhere. I hope the only "rattle" I hear now will be the jingle of my little "Gremlin Bell" (of course that would be for a different thread)
I tore down the front of the bike again (even took the crash bars off).
Removed and replaced the motor mount bolts and nuts with all grade 8 hardware. Changed the oil and cleaned out the fins on the oil cooler with engine cleaner and water (plus a generous amount of high pressure compressed air). I had to remove the oil filter to get a torque wrench on one of the mounting bolts, and there was almost 3000 miles on the oil so it seemed like a good idea.
Put everything back together using red Locktite and my newly aquired Sears torque wrench. Torqued every connector to spec as listed in my repair manual.
With a little luck, nothing up there will be comming loose anytime soon, plus I'm hoping that cleaning the oil cleaner will make the bike run a little cooler....and maybe help solve my problem with finding neutral when the bike has run for a while.
Good for you.......very thorough and you can feel confident that it is sound.
You said red loctite, not blue. Did the manual call out for the super-duty red for those bolts? Wherever you have the red the bolts would shear before backing off guaranteed.
