TTS Mastertune -Please post your DIY experience
Old Sep 24, 2010 | 09:51 AM
shortride's Avatar
shortride
Other than the ability to change settings, will the TTS do any more than an original SERT tune/map from the dealer?
Old Sep 24, 2010 | 11:03 AM
vtwinbmx's Avatar
vtwinbmx
Originally Posted by db2753
I read the instructions and was still confused or nervous so I had my kid help me and he installed the canned map for me.
I have an 05, no 02 sensors that I know of. Can I use the V-Tune?
No you can't v-tune without o2 sensors
Old Sep 24, 2010 | 07:50 PM
Lonewolf176's Avatar
Lonewolf176
Originally Posted by sifularson
Does anyone know if there is a feature for comparing calibration tables? Can't find anything in the manual.
When you have a map open, under the "edit" button you can copy multiple tables. Then you just open another map and paste multiple tables. Then under "table comparison" you can compare the edits to baseline or original.
TTS is actually the an upgraded version of the SERT, with more tools in the box. If you mean the SESPT, I still think the TTS has more features and is easier to use.
Old Sep 24, 2010 | 07:55 PM
Lonewolf176
You can get a kit to add the o2 sensors and then you just need the 18mm bungs in your pipes.
Old Sep 27, 2010 | 09:35 PM
sifularson's Avatar
sifularson
Originally Posted by boogaloodude
Have you asked over on HTT? Lots of TTS users over there. I've read the manual, but haven't actually played around with one yet.
Can you help me find HTT????
NEVERMIND . . . Google helped me.
Old Sep 28, 2010 | 08:32 AM
jkelley's Avatar
jkelley
Not that hard, there are some on this site that are very good with it. TTS is great especially if you either don't have access to a good tuner or don't want to spend money on a Dyno. I have learned a lot from several folks here.
Old Sep 28, 2010 | 03:46 PM
icufltrn's Avatar
icufltrn
Steve used to make the sert for Harley but something happened and they parted ways. He now makes the TTS using the insider knowledge he already had. Talked with him recently and he just released the 2011 calibrations. This is the way I will be going as soon as I have the funds.
Old Sep 28, 2010 | 09:00 PM
rkoivisto's Avatar
rkoivisto
Default Confusion factor
OK, here's what confuses me about the TTS. You've got to have the narrow band O2 sensors, which are worthless in the AFR area we all want to run in. So what good are the O2 sensors unless you are running14+AFR?
How can you get decent results from a control loop that is using a narrowband sensor, that won't operate in the range you want to control to?
I know this sounds confrontational, but it's not. The above question is what confuses me about TTS. I have heard a lot of good things about TTS, but as a control engineer, it doesn't make sense to me.
I would appreciate any information that would enlighten me.
Old Sep 28, 2010 | 09:15 PM
RK14SGS's Avatar
RK14SGS
I have a SEPST. Assume the TTS is fairly close in logic used. The AFR table should be set to something richer than 14.6 in areas where you want power. How rich is left up to you, just make sure timing is addressed in conjunction. I only have my 20-50% cells in cruise RPM range of 2000 to 3500 set at 14.6, where the O2 sensors can switch as designed to maintain a good cruise condition and gas mileage. All other AFR values are richer, ranging from 14.2 to 13.1, dropping numerically in value with increasing RPM and MAP pressure. The O2 sensors will only operate in cells where the AFR is 14.6 and closed loop, and going to WOT renders the O2 sensors useless, since they are not switching any longer at that point and the bike is in open loop mode. The ECM will command fuel based on TP, MAP, and other variables via look up tables, so based on the load at any given moment, the ECM will deliver fuel to satisfy the desired AFR cell entry. The VE tables need to me optimized for both front and rear cylinders to satisfy the AFR value, which comes from Smart tuning, akin to V tuning, as I understand. I am not an expert, just sharing what has taken me nearly a year to fine tune. Good luck...
Old Sep 28, 2010 | 10:01 PM
Lama's Avatar
Lama
I just spent 3 weeks tuning my 2011 bike with TTS. It was a learning experience let me tell you....
My advice, if you decide to only V-Tune, and you install a camshaft, make sure it is one of the cams that TTS has a pre-built map for.
Trying to tune around a non TTS loaded cam is a pain.
It can be done, but it takes alot of work. You are better off just installing an SE cam per the TTS Delphi Cal chart, and go from there.
After all I went through, I do have to say, it is a wonderful tuning device, and it can make the motorcycle absolutely RIP!!! But, that comes with many, many tanks of gas and many days of scratching your head.
Also, I found the 2011 (044) cal files did not give me a good tune, the 2010 (009) gave me the best tune.
My $.02
