Which side of Molex connector to release wires?
Old Sep 24, 2010 | 05:38 PM
r8rs4lf's Avatar
r8rs4lf
Default Which side of Molex connector to release wires?
Going to start feeding wires through bars. Which side to release?
Wires side or pin side? I see on the pin side there are these small holes.
Old Sep 24, 2010 | 05:55 PM
Roadie09's Avatar
Roadie09
try the wild one website, it has examples of what you need.
http://www.wild1inc.com/techtipswiring.html
Old Sep 24, 2010 | 07:12 PM
r8rs4lf's Avatar
r8rs4lf
That's an excellent link! Thanks alot!
Got the wires out of the left switch control. Fairly easy once I figured out how it works.
OK, I'm going to try to word this right.......
Those of you who have internally wired your own bars, did you cut the small zip tie inside the left switch control to get the it further (more harness) away from the end of the bar? With the switch control wiring harness pulled all the way through the bar, it seems it needs to go a little further for the grip to fit all the way on the bar. If I mount the control where it is, the bar doesn't slide all the way to the end of the grip. Just needs a little more. Did you cut the zip tie or just push the control over to get the grip all the way on?
JWDMAX
Mar 27, 2012 07:11 PM
pettifogger1
Aug 13, 2011 04:28 PM
gasol1ne
Apr 8, 2011 07:58 PM
jshull
Nov 5, 2009 04:27 PM
EriCal
Sep 22, 2007 01:04 PM
