High voltage reading ?
Old Sep 24, 2010 | 08:00 PM
kjkustoms's Avatar
kjkustoms
Question High voltage reading ?
Heres a question for all who can answer. I have noticed latley that my volt gauge is reading about 14.5 volts all the time, no matter if I have a full load ( spot lamps, heated grips, etc.) or nothing on at all. Is this normal? I asked the dealer today, he said it could be regulator or stator problem. They would have to run a diagnostic to find out. What are your gauges reading?
Old Sep 24, 2010 | 08:22 PM
piasspj's Avatar
piasspj
It should be reading about 14v and should be steady. That is what a regulator does, it regulates the power coming from the stator to prevent overcharging the battery.
Old Sep 24, 2010 | 08:26 PM
hojones's Avatar
hojones
Put a digital volt meter on the battery or the charger pigtail with the bike running and compare the reading to the VM in the dash. More than likely the gauge is bad.
Old Sep 24, 2010 | 08:29 PM
hogginit's Avatar
hogginit
Hey, it's good, working as it should. Would not screw with it.
Old Sep 24, 2010 | 08:37 PM
Londonbike's Avatar
Londonbike
mine has read just over 14 volts since new 3 years ago
Old Sep 24, 2010 | 10:50 PM
j1mmy's Avatar
j1mmy
mine is just over 14v.. only changes when i turn off ign.
Frogprince
Apr 9, 2024 10:08 AM
Dan33klein
Milwaukee Eight (M8)
May 29, 2019 03:01 PM
interceptor143
Oct 17, 2018 02:59 AM
RideFree1267
Electrical/Lighting/Alarm
Nov 28, 2017 05:05 PM
Ultra103
May 26, 2013 08:51 AM
