Bushings came loose on my RK
Old Sep 27, 2010 | 10:01 AM
HDBRATT's Avatar
HDBRATT
Default Bushings came loose on my RK
I went down to seabring yesterday and on the way back I noticed my new apes were loose(while going 75 on the highway). So pulled over and low and behold yes the bushings were loose.Had to have it towed last night by some friends. My bike is over at HD now being worked on. Have any of you that have changed over to apes had this issue? I remember seeing a post awhile back on this issue just couldn't find it.
Old Sep 27, 2010 | 12:25 PM
head's Avatar
head
i have had it happen as well. you can tighten those without having to tear the nacelle apart on some models. not sure about the 09 though. on my 06 i can turn the front end all the way and tighten one side at a time from underneath. seems like they require a 3/4 wrench.
head
Old Sep 27, 2010 | 12:38 PM
petemac's Avatar
petemac
The new bikes have a one piece riser clamp instead of the two piece from a few years ago. People that go with apes tend to change to the one piece and also replace the rubber bushings with poly ones. These two things usually fix the problem. I just went with the new one piece clamp and the poly bushings on my bike.
Old Sep 27, 2010 | 12:43 PM
Beemervet's Avatar
Beemervet
OPs bike is an '09, so it has the one piece clamp. Lock-tite should take care of the problem.
Old Sep 28, 2010 | 04:19 PM
robvg's Avatar
robvg
'09 RK here.....installed 16"ers last year and replaced the stock bushings with polyurethane ones....torqued em down to factory specs...no need to go tighter....don't forget your blue loctite
Fl Jimbo 05
Nov 19, 2011 10:13 PM
schwingding
Apr 3, 2011 09:24 PM
jrspringer06
Jan 17, 2010 10:16 PM
jsbridgew
May 21, 2008 08:35 AM
Uncle D
Sep 17, 2007 09:25 PM
