Cam Cover Question??
Old Sep 27, 2010 | 08:37 PM
Yachtman's Avatar
Yachtman
Default Cam Cover Question??
If I'm checking my cam tensioners and etc, will I lose any oil if this is done while the bike is on the kickstand?
Thanks!
Old Sep 27, 2010 | 08:56 PM
user 8373900's Avatar
user 8373900
Probably not much if it's on the stand. There is only supposed to be 6 oz in there anyway. More than that and you have other problems.
Old Sep 27, 2010 | 10:52 PM
Yachtman's Avatar
Yachtman
Thanks! I appreciate the reply.
Old Sep 27, 2010 | 11:33 PM
j1mmy's Avatar
j1mmy
you will loose a little, put a bowl or somthing under there
Old Sep 28, 2010 | 07:04 AM
Bfazona's Avatar
Bfazona
You will def lose some oil when taking off the cover. I just had a rag ready when I swapped my cover & wish I had a bowl or container to catch the oil.
Old Sep 28, 2010 | 08:53 AM
mainshaft's Avatar
mainshaft
Are you checking the tensioners on the 01 RK, if so how many miles on it?
Old Sep 28, 2010 | 09:04 AM
DrPlastic's Avatar
DrPlastic
I lost about a 1/2 a cup when I pulled mine last Saturday. Put some foil and form a tray that will allow the oil to drain away from the engine and into a pan and not under and all over the frame and engine!
Hannibal Smith
Shovelhead
Nov 13, 2018 09:25 PM
dajogejr
Apr 23, 2016 07:22 PM
aroz34
Jan 14, 2014 06:10 PM
Ironslug
Sep 11, 2011 08:56 PM
ranger_blackhat
Electrical/Lighting/Alarm
Jan 19, 2009 11:00 AM
