Still cant find problem
Old Sep 28, 2010 | 12:41 PM
sal537's Avatar
sal537
Default Still cant find problem
Have a 2005 ultra got used w/ bad chain tensioners etc. put in new style cam plate w/ andrews cams and she went great for a few weeks. Coming home other day noticed on oil temp gage goin up. It allways ran @ 220-230 and now was headin for 300. Made it home and since have changed wires, plugs, oil, filter, front motor mount, new battery, and reprogramed pciii w/ new map they gave me for cams pipes etc. After all this it still not ok as the plugs look extremely lean, running hot, and wont go over 3000 rpm w/ no power. Also changed fuel filter and gas tant was clean, thought maybe water? Out of ideas except dealer which i hate to do. Any thoughts?
Old Sep 28, 2010 | 01:17 PM
user 8373900's Avatar
user 8373900
If you didn't get the oil pump aligned correctly, or cut an O-ring it is "dry sumping" and will cause some of the symptoms you describe.Especially the loss of power.
Old Sep 28, 2010 | 01:44 PM
LozoB's Avatar
LozoB
Post in the Technical Forums under ignition/ecm etc... May get better response.
blackflame
May 13, 2016 06:29 AM
jbmunnoch
Dec 15, 2010 12:46 PM
sal537
Oct 12, 2010 02:35 PM
sal537
Sep 28, 2010 02:12 PM
tgarrett1
May 25, 2010 08:45 PM
