cams installed, couple questions?
Old May 12, 2016 | 05:35 PM
blackflame's Avatar
blackflame
Default cams installed, couple questions?
Just had some Andrews 26 cams installed.
I plan on changing the oil even though it only has 12 miles on it lol. Should I changed the filter also, again brand new.
Also seems like only my rear cylinder is getting that cam "loop" front is more steady thump.?
Thanks
Old May 12, 2016 | 05:57 PM
Steve Helton's Avatar
Steve Helton
Thanks
My thoughts is if you started it since the cam install i would change it if not should be fine.
Old May 12, 2016 | 06:00 PM
brad75raiders's Avatar
brad75raiders
I wouldnt change the oil or filter if it was my bike. You can time the cyl. During dyno if there seems to be a problem
Old May 12, 2016 | 06:05 PM
springers4ever's Avatar
springers4ever
Cool oil change ???
why are you changing the oil if it was just done ...??? crank it and ride it around the block a couple times ...then top it off !!!
leave the filter too ...!!!
no need ...just a waste of good oil ....
just our 2 cents ...!!!
Old May 12, 2016 | 06:09 PM
Stiggy's Avatar
Stiggy
Did you use gobs of assembly lube when installing the cams? If not, I can't share the logic of dumping fresh oil.
Old May 12, 2016 | 06:17 PM
Dozer40's Avatar
Dozer40
Nothing wrong with oil with 12 miles on. Save yourself some time and money and ride. A little assembly lube won't hurt a thing.
Old May 12, 2016 | 08:26 PM
blackflame's Avatar
blackflame
Had a indy do it so no clue about how much lube he used,,, I'll change in a couple hundred .
Old May 12, 2016 | 09:00 PM
svarnster's Avatar
svarnster
do what makes u feel comfortable.
Old May 13, 2016 | 06:29 AM
todd-67's Avatar
todd-67
I just did a cam swap with fresh oil. I changed it during the swap and plan on swapping it out after 500 miles. Oil is cheap. I have 0 argument one way or the other. It's your bike.
nsp261
Oct 5, 2016 08:37 PM
shorty07ultra
Dec 14, 2013 01:06 PM
jefla
Apr 13, 2013 11:27 AM
Lawdawg
Aug 5, 2011 12:33 PM
arnold
May 23, 2011 12:14 AM
