Fueling Oil filter/cooler
Old May 21, 2011 | 04:30 PM
arnold's Avatar
arnold
Default Fueling Oil filter/cooler
Dont buy one, about $500 and it stops your top end from oiling, I caught it early and all I had to replace were the cam chain adjusters, lifters, cams, (I was wanting to put in cams anyway but I didnt expect them to be worn).
DONT INSTALL ONE.
http://www.feulingparts.com/product....ategory3=Black
Old May 21, 2011 | 11:22 PM
Los11's Avatar
Los11
DONT INSTALL ONE.
Hey tha nks for the heads up but can you be more specific and explain what happened how you know it was the oil cooler etc etc.. Thanks
Old May 22, 2011 | 10:18 AM
arnold's Avatar
arnold
I noticed noise in my top end, mechanic thought it was related to the items I replaced, but after replacing noise was still there (Parts were worn, including cams). I had inspected the chain tensioner's 10,000 miles ago when I added the filter, they looked like new, they were inspected at my request while I had the pipes off wrapping them.
Trying to discover what was wrong after replacing parts we pulled the top off and found that there was no oiling on the top end, mech said lets pull that fancy filter and see what happens, I said ok, pulled the filter and it immediately started oiling. Filter was maintained as directed by Fueling.
Bike is running great with the 204 cams, I wanted to do that mod anyway, just glad I didn't do any more damage than I did.
It was proof nuff for me.
Old May 22, 2011 | 10:31 AM
8541hog's Avatar
8541hog
Just curious, have you lowered your idle speed at all?
Old May 22, 2011 | 02:46 PM
arnold's Avatar
arnold
Absolutely not, 08 96 inch needs the stock idle for oil pressure, thats why they idle higher than the old bikes, no more potato potato
Although the 204 DOES have a very nice lope.
Old May 22, 2011 | 03:05 PM
dlstanf2's Avatar
dlstanf2
Have you sent a letter to the manufacturer? If this part failed I'm sure they would make good on the part, especially if it were a manufacturing problem.
Old May 22, 2011 | 06:01 PM
8541hog's Avatar
8541hog
I was curious because the MoCo recommends the Fueling oil pump if you want to lower the idle below 1000 RPM,
Old May 22, 2011 | 09:30 PM
arnold's Avatar
arnold
Ill call them this week
Old May 22, 2011 | 11:18 PM
Los11's Avatar
Los11
I am running the Feuling oil Pump with my 107 imo great upgrade..
Old May 22, 2011 | 11:55 PM
Swede405's Avatar
Swede405
DONT INSTALL ONE.
That's a pretty blanket statement. I'm sure there was something more specific to your bike going on since a lot of people run oil coolers just fine. If you know what specifically caused your issue or if it's a specific cooler let us know.
