View Poll Results: What rpm range do you normally ride in?
2000-3200
47
49.47%
2000-3600
23
24.21%
2000-4000
20
21.05%
2000-6000
5.26%
Voters: 95. You may not vote on this poll
RPM Range Average
Old Sep 29, 2010 | 04:22 PM
lionsm13's Avatar
lionsm13
Default RPM Range Average
Just out of curiousity;
What RPM range do you guys ride in and what cams do you run?
I find that I generally run in the 2000-4000 range, but probably mostly average in the 3000's and that is a stage 1 set up/PCV with the stock cams in the 09 96 inch motor.
Old Sep 29, 2010 | 05:25 PM
qtrracer's Avatar
qtrracer
Around town 2500-3500 but I will crank her up to the 6k area every time I ride her. DME 575L cams.
Old Sep 29, 2010 | 05:31 PM
caspr2's Avatar
caspr2
I never ride below 2500 and my motors sweet spot is about 3200.
Old Sep 29, 2010 | 05:35 PM
'05Train's Avatar
'05Train
On a flat road, I shift into 6th at 2,000 rpm. If I'm taking it easy on the backroads, I'm usually around 2,800-3,000. If I'm really rolling, I have no issues holding the motor above 5,000 rpm for extended periods of time.
Stock heads and cams, Stage 1.
Old Sep 29, 2010 | 05:36 PM
bald1der's Avatar
bald1der
My average range is between 2800-3800. I will run up to 4-5k though. 96" with SE-211's
Old Sep 29, 2010 | 06:44 PM
The Old Man's Avatar
The Old Man
I have stock cams...I run 2000 to 3000 cruising down the road. Cruising around town I run what ever gear gives me the speed limit I want and keeps the engine at 2200 to 2400 rpm. That keeps me on the point to just blast off and not need to shift etc....Helps with the gas milage too!
Old Sep 29, 2010 | 07:03 PM
Chuck1's Avatar
Chuck1
Stage one, stock cams in my 10 Classic. I run between 2000 and 2500 on average.
Old Sep 29, 2010 | 07:18 PM
nemick's Avatar
nemick
I usually run between 2500 and 3500 when cruising around. I usually take her up to 5500-6000 each time I'm riding at some point though. I'm using Woods TW6-6
Old Sep 29, 2010 | 07:33 PM
piasspj's Avatar
piasspj
Totally stock motor, a/c and pipes.
I'll run above 4k before shifting but ride right around 2500.
Old Sep 29, 2010 | 08:02 PM
NoCoLoco's Avatar
NoCoLoco
Stage 1, stock cams. I "cruise" in the low to mid 2's. I shift between 3000 and 5000 depending on...
