left turn signals
Old Sep 30, 2010 | 02:09 AM
rdbateman's Avatar
rdbateman
6th Gear
Default left turn signals
security light comes on when i turn on left turn signal. i have chaged bulbs. running lights work. help please! need turn signals
Old Sep 30, 2010 | 04:55 AM
Roadan's Avatar
Roadan
That happened to the wifes 08 Classic last month. Turned out to be the "run, brake, turn sig. module" had crapped out. Removed and reconnected the rear brake/ turn sig. wires and all was good. If you have one of these, try disconnecting it.
Old Sep 30, 2010 | 06:41 AM
KutenFLHX's Avatar
KutenFLHX
What model bike? Upgrade to LEDs? What mods have you done?
Old Oct 1, 2010 | 01:50 AM
rdbateman's Avatar
rdbateman
6th Gear
ok will do. could you tell me where it is located/ i have 06 road glide. thanks allot
Old Oct 1, 2010 | 12:37 PM
rshwetz's Avatar
rshwetz
I would recommend that you check the left signal wiring for a short. I had the same issue, when the signal is turned on the bulb does not go on and the red key shows up. Check the wiring for rubbing on metal.
Old Oct 1, 2010 | 07:04 PM
Roadan's Avatar
Roadan
The "Run, Brake, Turn Sig. Module" is an accessory that would have been added by you or a previous owner (if there was one). It will make your rear turn signals into additional brake lights as well retain the turn signal function.
If you have one it would be under the seat in-line with the wires that go to the rear of the bike.
rgilkerson
Electrical/Lighting/Alarm
Mar 22, 2020 09:13 PM
clap
Sep 19, 2017 11:38 AM
thyvipera
Jun 28, 2017 07:21 PM
bunotz
General Topics/Tech Tips
Jan 18, 2014 02:31 PM
Sledge
Nov 10, 2012 01:34 PM
