I was replacing the fuel lines on my 97 Ultra, leaking fittings at the tank, and I notice the return line engine side post is loose. How is the post fastened to the injector? I see a large tork nut holding a large clamp which looks like it holds the posts and injectors. What is loose under the post and can I just remove the tork nut and clamp plate and replace something? I do not want to go too far unless I know more. Seems like a lot to have to buy the shop manual but may have too.
I agree, I will buy the books. I did find the schematic and decided I did not have an additional leak. The replacement lines work great even though I am not high on the quality of the manufacturer. The return line is slightly too long and twisted. It appears to be working fine but could have been better. Leaks all fixed and bike running great for now. Now all I need is a good job and one of those great looking trikes I saw at the dealer, 103 inches and great looking. Costs as much as my new van.
Originally Posted by paulhog I had the exact same problem with my '99 RK. Seems to be a common problem. The HD lines will cost you almost $200 EACH! J&P Cycles has this for $160 for BOTH.
did you remove the manifold or just access star drive bolt on top of the clamp. i'm having the same leak issue and want to know if it's eaiser to just remove the manifold?
