Help me ditch those reflectors
Old Oct 8, 2010 | 03:36 PM
Irish Hogster's Avatar
Irish Hogster
Default Help me ditch those reflectors
I've just realised that the reflectors on the front fender just look naff - can anyone give a tip for removing them?
Thanks
Trev
Old Oct 8, 2010 | 04:00 PM
dansflhti's Avatar
dansflhti
I ditched mine by removing the front bumper.
Old Oct 8, 2010 | 04:32 PM
pro2slow's Avatar
pro2slow
Yep,..... gota get rid of that ugly front bumper
Old Oct 8, 2010 | 07:20 PM
piasspj's Avatar
piasspj
I can't even see the fender when I ride, why worry about it.
Old Oct 8, 2010 | 08:55 PM
BackAt5O's Avatar
BackAt5O
I pulled all the reflectors off and peeled off the warning decals with my fingers. Then removed the glue with Loctite 770 primer and Duck brand adhesive remover, a micro fiber towel, and a lot of patience.
Old Oct 8, 2010 | 09:04 PM
1931jamesw's Avatar
1931jamesw
Use fishing line as a cutting tool to remove them. It will usually get the adhesive off with the reflector if your careful. If the adhesive doesnt come off, use carb cleaner on a rag or paint thinner but be careful not to get it on your paint.
boom23's Avatar
boom23
You can pull them off slowly with your fingers. The reflectors might break but you probably don't care (I did not). You can also use fishing line, or dental floss, to cut the adhesive. Once the reflector is off, you can use your fingers to slowly remove any large remaining pieces.
I used the Orange glue removal product to disolve any remaining glue. You might want to wax the paint when you are done.
Old Oct 8, 2010 | 09:10 PM
MADDOG187's Avatar
MADDOG187
i was told , but havnt tried it myself to pour boiling water gently on the top edge where it connects to the paint , loads of it , then they just pull away , clean any left over glue with turps , the guy who said didnt have any paint probs
Old Oct 8, 2010 | 09:33 PM
JAKE 2544's Avatar
JAKE 2544
Fishing line works great but be sure to keep it close to the reflector side or it will scratch the paint.then use goof off to remove any left over adhesive.
Old Oct 9, 2010 | 07:35 AM
SMSgt B's Avatar
SMSgt B
Use a hair dryer on them and get it nice and hot ... glue will loosen up and they will come right off.
