oxygen sensors?
Old Oct 12, 2010 | 03:24 PM
hydrolock43's Avatar
hydrolock43
Default oxygen sensors?
Wondering if leaving them in the pipe unplugged will screw them up for later use? I have them in the pipe but unplugged using a pcv and noticed that they are black sooty. I figured that i would leave them in as i will try a se tuner in the future.
Old Oct 12, 2010 | 04:45 PM
user 8373900's Avatar
user 8373900
It is the same exhaust going by if they were plugged in...I left mine in to use in case the PCV goes **** up. Can't imagine a problem.
Mark
Old Oct 12, 2010 | 04:52 PM
Gearhead3's Avatar
Gearhead3
I woudn't leave them in. They operate at temps of 600 + degrees to keep them from getting fouled. Pull them out and go to your local Toyota dealer and ask for P/N 90341-18016. This will get you a Toyota truck oil pan drain plug which will thread right in to an O2 bung. They're only a couple of bucks a piece. Use some high temp RTV on the threads (they don't come with a gasket) and you'll be all set. This is for the larger of the two types of O2 sensors, not the smaller ones. The later model HD's (11's and maybe even '10's) have the smaller ones. As a side note...I know people who have left there's in and unplugged, and had to use a propane torch to burn the carbon off when they've decided to hook them up again. (Yeah, it's low buck...but it works) LOL
Old Oct 12, 2010 | 07:52 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the plugg doesnt supply heat so i dont get why they would run any colder or foul,unless the map on the pc was way rich.
Old Oct 13, 2010 | 03:11 AM
Watch Guy's Avatar
Watch Guy
Default Leave them in
No damage occurs whether plugged in or not. Also, if your fuel management system quits, then you can just unplug it and reconnect the stock ecm and sensors.
Old Oct 13, 2010 | 10:12 AM
user 8373900
Actually, the 2011 sensors are heated, but I still doubt it will hurt them to leave them in.
Mark
sirrat007
2014-2024 Touring Models
76
Aug 9, 2020 10:15 AM
vinegar
May 31, 2017 12:19 PM
cursedspirit
Apr 16, 2012 06:12 PM
BLKnCHRME09Deluxe
Aug 22, 2010 09:12 AM
hydrolock43
Apr 17, 2010 05:36 PM
