spring tensioner shoe replacement help
Old Oct 27, 2010 | 05:32 PM
WZDADS's Avatar
WZDADS
Get her back together yet?
Old Oct 27, 2010 | 08:45 PM
jackinthebox's Avatar
jackinthebox
Yeah got it taken care of. Since I was having the cams pressed out again I just took it as a sign because I was going back and forth between the upgrade cam plate and pump so I took the dive. Here's a pic of the new camplate with cams in. I just got done installing the new torrington inner cam bearings in. Thx
Attached Thumbnails spring tensioner shoe replacement help-img_1994.jpg   spring tensioner shoe replacement help-img_1993.jpg   spring tensioner shoe replacement help-img_1991.jpg
Old Oct 27, 2010 | 09:47 PM
Yachtman's Avatar
Yachtman
Sounds like you got it squared away. It's amazing how different the Screaming plate looks compared to the old one.
Old Oct 27, 2010 | 09:49 PM
WZDADS's Avatar
WZDADS
And the added benefit of the oil pump with it...
Old Oct 27, 2010 | 09:59 PM
city wrench's Avatar
city wrench
4th Gear
did you think of going to the se cam plate it has hyd tennsioners. they dont have as much pressure on them as the spring tennsioners do. the hyd ones will last longer and it also helps reduce premature inner bearing failure.
i have done many cam tenn jobs @ diff milage ( from 1200 to 60000 mi ) you just never know when they will fail do yourself a big favor and change the cam plate and go with th se kit . with this kit you dont need special tool to unload or load the springs
i see you already invested in the new plate my bad new to this site i must have missed some posts good move by the way
Old Oct 27, 2010 | 10:40 PM
jackinthebox
Yeah Ive heard alot of good things about the upgrade kit only a few bad comments. Something about the andoizing causing issues and the too much oil pressure. But I think its going to be a good upgrade!
Sandcrab
Oct 1, 2020 11:32 AM
Freedom
Exhaust System Topics
May 6, 2020 10:54 AM
Dieselhed
Mar 30, 2011 06:01 AM
Neil
Oct 3, 2008 06:50 PM
Road King Kid
11
Jan 14, 2008 06:22 PM
